Vizio E470VA Logo lights up white but nothing else comes on
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Hi everyone. First post here but I've done plenty of reading. I have a background in Electrical Engineering so I'm new to the TV repair but certainly not electronics. I've managed to fix a few already on my own from just reading other posts but wanted to check on this one before I proceed. Anyway, on to the point.
    I picked this one up cheap on craigslist a few days ago. As soon as the power is connected the VIZIO logo lights up white (never shows the amber standby). At this point nothing responds or can be done to change anything. There is no backlight or anything else. I've checked all the voltages going out of the power supply and everything reads zero except for the two 5V feeds going from the PS to the main control board. I've unplugged the inverter board from the PS and disconnected everything from the control board except the 3 wires going to the logo light and it has the same result. This leads me to believe that its either got to be the power supply or the control board. I figured the power supply should be putting out some voltage other that 5V even in standby but wasn't sure.
    Thanks in advance for any help and I can post pictures later today if needed!
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Vizio E470VA Logo lights up white but nothing else comes on
    I thought I'd go ahead and post a picture of a power supply like what I'm dealing with. This isn't my actual picture of course but is identical. With the power cord connected and the VIZIO logo lit up white on the front, the only power I'm getting from the PS is the two 5V outputs shown coming from the jack at the bottom right of this picture.
    Again, I can post actual pics of my stuff this evening but wanted to get a jump on it. Everything on my PS physically looks to be ok.
    • johnboy1313
      • Nov 2012
      • 1959
      It's likely the EEPROM on the main board. You can buy the component for ~$25 and solder it on yourself or send it to be repaired for ~$50. Do a google search for the part number on the main board and the word repair.
      • aaronwt6
        • Apr 2013
        • 855
        • US
        I'll check into that right now. Plan on fixing it myself for sure. I've got plenty of soldering experience as well as a hot air station for removing chips. Should be no problem.
        Thanks for the advice!
        • aaronwt6
          • Apr 2013
          • 855
          • US
          Is there any way to obtain the eeprom flash for these chips and do it yourself? I'd need to get the numbers off the chip first but I figure its most likely been corrupted rather than a bad chip?
            It almost certainly is simply corrupted. If you have a programmer and hex file you can do it. Many people can get programmers cheap but the people doing these programming services keep the hex files close to their chest so you're SOL unless you can copy it off the new chip (for future fixes) or get it from somewhere else. I've encountered a few hex files, none for Vizio though.
            • aaronwt6
              • Apr 2013
              • 855
              • US
              Thanks Tom. I have the chip on the way already and I'll certainly be keeping a read of it.
              • aaronwt6
                • Apr 2013
                • 855
                • US
                Well, I have an update. Not the one I was hoping for but I guess its progress. The TV now shows the amber standby light and responds to the remote when I turn it on. The light changes to white and the backlights come on. However, all I get on the screen is what is shown in the attached picutres. Doesn't look to me like the screen is physically damaged or anything.
                Ocasionally these lines don't even show up but usually they do. The rest of the time just the backlight comes on.
                Let me know if anyone has some additional advice.
                Thanks,
                Aaron
                • hienton2
                  • Sep 2009
                  • 183
                  Do you have the right eeprom programed? I see alot E470VL model.
                  • aaronwt6
                    • Apr 2013
                    • 855
                    • US
                    Got the chip pre-programmed on EBay. I'm assuming it was done correctly.
                      Looks to me like the LCD panel may be bad too, could be bad tab bond. Maybe fixable. Perhaps turning the TV on and off rapidly corrupted it, the owner may have tried this after it showed the fault.
                      • aaronwt6
                        • Apr 2013
                        • 855
                        • US
                        Well crap. That's certainly not what I wanted to hear. I'll let you guys know if I get anywhere with it.
                        I did reseat all the ribbon cables going to the panel but no change.
                        Thanks again.
                        • hienton2
                          • Sep 2009
                          • 183
                          Does tv have sound?plug in composite video , change input source.
                          • aaronwt6
                            • Apr 2013
                            • 855
                            • US
                            I'll try to check that when I get back to the house in a bit.
                            • aaronwt6
                              • Apr 2013
                              • 855
                              • US
                              Ok. Checked for sound. It comes on but sounds choppy and only the left channel works. It cuts out every few seconds.
                              Seems like something is still up with the control board.
                              Should I keep messing with it or call it a wash?
                              • topfli8979
                                • Oct 2012
                                • 311
                                I had this same tv, picked it up with no picture. Found bad main board, replaced all is well now.
                                • aaronwt6
                                  • Apr 2013
                                  • 855
                                  • US
                                  Ok. May have to resort to that. Hate to just trash the thing. Like I said, I did make progress on it with the EEPROM.
                                  • hienton2
                                    • Sep 2009
                                    • 183
                                    May be new main will fix the tv.
                                    • aaronwt6
                                      • Apr 2013
                                      • 855
                                      • US
                                      Well, I have a new update on this. Replaced the entire main board. TV now turns on and has a beautiful picture. However, every 5 seconds or so the picture goes out for about 1/2 a second. I read this other thread that rogmiller started and it sounds like the same issue.
                                      https://www.badcaps.net/forum/showth...ghlight=e470va
                                      This was a used main board so I figure maybe its bad too. I guess I'll see about a return and hopefully the guy has another he can swap me with.
                                      Thanks again for everyones advice / suggestions!
                                        Tried this?
                                        While holding down (UP ARROW) the on the Remote Commander, press the
                                        POWER button on the Front Panel of the set.
                                        The set restarts and displays the initial setup screen. This may take
                                        several minutes.
                                        • Daveleone
                                          Vizio VO42L, white logo, no backlight, no picture
                                          by Daveleone
                                          Hi all! I've got a Vizio VO42L. Plug it in, and logo flashes orange/white for a bit, then solid orange. Press power, and logo changes to white. There is no backlight.
                                          From reading some of the posts here I thought the inverter could have been the problem, but I've replaced it and still have the same issue. I noted that shining a flashlight on the screen shows nothing, so now I'm thinking main board?
                                          I took the following readings with the TV powered on. I also tried taking the readings with the CFL connectors unplugged - no change.
                                          Main board:
                                          Continuity across...
                                          02-20-2021, 04:52 PM
                                        • crewdog
                                          Hp 15-dy2087nr white lights blinking
                                          by crewdog
                                          Board DAOP5HMB8F REV F
                                          Model OPSH
                                          No bios battery on board
                                          Power at cord 19.7, swapped cord 19.7V just to test, tested lid switch good
                                          Plugged in, battery in, charging port light on solid white, press power button, no fan spin, charging connector
                                          and power on light both blink white, not in sync, battery voltage 12.2 jumps to 13.0 for a second and then back and repeats.
                                          Not plugged in, battery in, press power button, no fan spin, power on only blinks white until battery removed, battery 12.7 - 12.1 for a second and then back and repeats....
                                          10-25-2023, 03:08 PM
                                        • Super360
                                          Vizio E701i-A3 Vizio logo flashing then turns off
                                          by Super360
                                          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                          07-25-2024, 07:06 PM
                                        • x_orange90_x
                                          Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                          by x_orange90_x
                                          I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                          12-28-2023, 06:26 AM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
