VIZIO P50HDTV10A One wide vertical band and clicks off after 10 sec.
  • capkid
    • Oct 2010
    • 1339
    Re: VIZIO P50HDTV10A One wide vertical band and clicks off after 10 sec.
    Hmm. I guess I'd question the meter's accuracy. If these readings are indeed accurate, you probably need to replace both buffer boards. Got a sample pic of your test?
    LG Plasma Mal-Discharge Correction Service
    • snake91876
      • Feb 2013
      • 236
      I was using an ideal digital. i will borrow a better meter from a neighbor today and repost results.
        Quite likely the bottom YDRV is the only fault.
        • capkid
          • Oct 2010
          • 1339
          Yeah, I was leaning that way myself. The bottom one is definitely bad. I'd try replacing the bottom board and see what happens.
          • snake91876
            • Feb 2013
            • 236
            well i ordered both bottom and top ydrv buffer boards and the top one came before the bottom so i said what the heck i will swap the upper board. Still the same issue so im hoping its the bottom board, i will update as soon as it gets here. Thanks
            • snake91876
              • Feb 2013
              • 236
              Well i have replaced the boards and now the wide band is gone from the display down the middle but i still have no picture. Tv is coming on and not throwing an error code and shutting down, it will stay on now. I have a solid black screen before it was pixelated a lil and the band down the middle. I also have no onscreen menus when i press menu or input i cant see anything changing. What next guys!
              • snake91876
                • Feb 2013
                • 236
                I forgot to say all the sound is working perfect too.
                  What have you replaced in total?
                  • snake91876
                    • Feb 2013
                    • 236
                    Upper and lower ydrv buffer boards
                    • capkid
                      • Oct 2010
                      • 1339
                      Connectors all seated properly?
                      • snake91876
                        • Feb 2013
                        • 236
                        I have double checked that, what if ysus is bad
                        • snake91876
                          • Feb 2013
                          • 236
                          Alright i got a piece of color back, if i unplug the top ydrv buffer board off of the y sus and unplug from bottom ydrv buffer i get color sequence on bottom half of screen with sound. I also get weird vertical bars in random patterns and stufff while switching inputs like this on the lower half of screen. I just cant undrstand whats going on , if this board is good should i be getting picture on bottom half, could we say its ysus now.
                          • capkid
                            • Oct 2010
                            • 1339
                            Hmm, it's possible you have a Y-sus problem - not sure, though. Do you have a pic of what you're seeing onscreen? I'd also remove the buffers and test them again with a meter.
                            • snake91876
                              • Feb 2013
                              • 236
                              the first pic is what i see with bottom ydrv buffer mounted and the upper unhooked from ysus and bottom ydrv. Thats the picture with half a screen.
                              the second pic with the whole screen lit is with both ydrv buffers hooked up on ysus and the ydrvs plugged toghether but the power wires that run to the upper ydrv buffer from the ysus unplugged.
                              Im at a loss here!
                              • capkid
                                • Oct 2010
                                • 1339
                                I'm probably just reaching here, but did you have the screws installed to connect the Y-buffers to the Y-Sustain? Those pics are making me hesitantly believe that the panel is bad, but I'd do a few more tests to rule out the Y-Sus or some other part.
                                  Looks like your new buffers are bad. Your Y-sus appears to be working OK, as the screen is properly lit. Please check the -Vy and Vsc voltages on the Y-sus.
                                  • snake91876
                                    • Feb 2013
                                    • 236
                                    At vsc tp the meter want settle off it fluctuates around 130-145volts and im not sure where to check the -vy could you tell me. thanks
                                      Vsc is bad. Should be closer to 180V.
                                      -Vy is measured across a resistor, labelled "-Vy". It's on there... somewhere.
                                      I doubt the panel is bad very much.
                                      • snake91876
                                        • Feb 2013
                                        • 236
                                        so i would need a y sustain board tom
                                        • snake91876
                                          • Feb 2013
                                          • 236
                                          Anybody , would i need a y sus board.
