I have a vizio p50hdtv10a i got for absolutely free out of my neighbors trash. It turns on and i get a display of one band of lines about 5 inches wide going down the very center, no other pic just some red pixeling around the screen. I unplugged the ysus board power and the band in the middle goes away and i have a full black screen but still after about ten seconds it clicks and turns itself off. What could it be professionals im used to lcds these plasma are a lil more complex. Can this be the display screen or most likely a board problem. Here are pictures of what its doing . These are with everything hooked up .
					VIZIO P50HDTV10A One wide vertical band and clicks off after 10 sec.
	Tags: None
 Re: VIZIO P50HDTV10A One wide vertical band and clicks off after 10 sec.
 It is probably going off because it receives no signal, that is a very corrupted no signal display
 This is a failed Y-buffer, if you are lucky, the Y-sus is OK, but I would recommend replacing that at the same time, on these LG/Samsung based plasma TVs.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
 Just happen to have one of these in my workroom. The TV does indeed go into standby when it "sees" no signal. I also concur the problem is the Ysus buffers (one or both).
 Does the screen change when you change inputs?Comment
 I havent tried other inputs , is there anyway to tell if its upper or lower y buffer. If i get new buffers and its the ysus that is bad will it hurt the new buffer boards.Comment
 Usually it's the top buffer but sometimes best to replace both. These are ugly sets in that a bad Y-sus can kill the buffer so replacement of the Y-sus is recommended... You can only really test with a scope.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
 For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
 would you say this is a good quality plasma to spend 100-150 fixing. I am an amateur fixing these for fun and personal use and not to sell. To date i fixed a insignia 47, and failed to fix an 46 samsung lcd with a bad panel. I would like to know if this has a decent picture before i spend the money to fix if i am sucessful. Thanks for your help. I just missed a panasonic viera 50 that would not turn on that i saw for sale for $50.Comment
 Not really IMO, there's not much difference between this and a big LCD -- newer plasmas definitely worth fixing but not old, LG/Samsung based ones like this.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
 Throw $50 worth of buffer boards on it. The TV should bring at least $225 to $275 fixed. I know you don't want to fix and sell, but the only way you know for sure what the picture looks like on the set is to fix it. Fix this one and graduate on to bigger and better sets.Comment
 im a little confused at what buffer boards i should be in search of i see the ones that say xl, xr, are these the x sus boards and i need the y buffer boards the ones coming off of the y sustain board.Comment
 i guess i need what is labled ydrv top 6871qdh088a, and ydrv bottom 089a, is this correct boardsComment
 Yes, 88a and 89a are the boards.Comment
 I had a similar problem before with an LG-based TV:
 http://blog.coppelltvrepair.com/2010...-lines-in.htmlLast edited by capkid; 04-19-2013, 05:55 PM.Comment
 On this vizio it looks as though the y drv buffer upper and lower are tied together. I unplugged the cable from upper y drv board and y sus board and
 i get really no change in picture. some posts said i could unhook one or the other and know that a board was bad by half the tv coming back on. If it is the top thats bad i guess there is no way to test this way is that correct to assume.Comment
 Ok i did a little more troubleshooting. With the upper y drv board off of the y sus high voltage pads and wires unhooked off y sus board i get the wide band of vertical lines on the bottom half of screen only. With the lower y drive board disconnected from y sus pads and wire from upper y drv board unhooked i get a solid black picture with no on screen menus . Trying to keep from buying both boards. Anybody got any ideas from this if it is upper or lower. I would test but my meter doesnt have a diode mode. Thanks for the help in advance.Comment
 Did you try to obtain resistance readings between the pads on each of the buffer boards (use "Ω" setting) with the boards removed from the TV? If so, what are the readings?
 Edit: If you decide to purchase the buffer boards, ShopJimmy shows that there are substitutes, which widens your search:
 6871QDH088A substitute = EBR30598201
 6871QDH089A substitute = EBR30598501Last edited by capkid; 04-19-2013, 11:08 PM.Comment
 Alright heres my test of my boards using an ideal meter with diode and ohm mode, can someone help with the results
 Ydrv top
 diode mode between gold pads
 1.109 one way and
 .479 the other way
 Ohm mode between gold pads in 200k range
 01.6 one way and
 01.6 the other way
 Ohm mode between gold pads in 20M range
 0.00
 0.00
 Ydrv bottom
 .018 and a beep from meter meaning resistance less than 30ohm
 .019 and a beep from meter meaning resistance less than 30ohm
 0.00
 0.00
 0.00
 0.00
 Can someone please tell me which board is bad if you can tell, thanks
 ahead of time!Comment
 Hmm, those readings seem odd to me. Both buffers may be bad. Did you try testing the mosfets for shorts? A simple test for shorts between drain and source may be sufficient. Per the Coppell blog, you only need to test one mosfet on each board, since the mosfets are in parallel.
 (1) Using diode mode, connect your red probe to the drain and the black probe to source. Record the reading.
 (2) Reverse the probes. Record the reading.
 Edit: I remember that I only had to replace the lower buffer in my TV, and it had the same part number as yours (6871QDH089A).Last edited by capkid; 04-20-2013, 09:20 PM.Comment
 All three upper ydrv mosfets read in diode mode
 .711 one way
 1 the other way
 Bottom ydrv mosfets
 .048 one way .049 the other way
 .005 one way .007 the other sets beep off on meter
 .048 one way .049 the other wayComment
 What meter are you using? I'm guessing the "1" is the same as "OL" as shown on most meters. If so, it looks like your bottom buffer is bad at a minimum. Replacing the bad mosfet will most likely restore it to working condition. You'd have to remove one of the mosfets to be sure of which one is actually bad, though, since they're in parallel. Too bad you're not close to me, as I have a few of those mosfets lying around in new condition.
 Edit: You may want to try just replacing the bottom buffer, since the top appears to be ok based on these readings. If you don't see any small pinholes in the top buffer's chips, it's likely the buffer is ok. There still could be internal chip damage, though.Last edited by capkid; 04-20-2013, 09:39 PM.Comment
 Wait i tested wrong pins should be right source to middle drain right
 bottom ydrv all mosfets in diode
 .019 one way and .018 the other and beep from meter
 top ydrv
 #1 .477 one way and 1.114 the other way
 #2 .477 one way and 1.114 the other way
 #3 .477 one way and 1.114 the other wayComment
 Assuming...7 Photos
			This specification for the ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To boardview and 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard...09-07-2024, 02:50 AM
			by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
 panel: au optronics T650HVN05.4
 72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
 link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
 Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
 https://www.shopjimmy.com/vizio-56-0...-power-supply/
 Vizio 55.75J01.001G (91.75J10.004G) Main Board...
			by howardc6449UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
 Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
			by mrtekHi.
 picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
 When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
 This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
- Loading...
