Finding replacement bits for a Panasonic Plasma SC board
Re: Finding replacement bits for a Panasonic Plasma SC board
Yes, sure, but if the cases are on their places.... :-)
It seems there has been a huge blow.....Comment
Working on one of these and blew it up. Replace evrything that i could find shorted. When i jump sc 50 i get the green light then it goes out. I found q16661 rjp6065 and it keeps shorting collector to emitter. There is no short when removed. I was poking around and found ic920 witch is NJM2903V JRC2903 TSSOP-8 at pin 4 to 5 and it corelates with emitter. I pulled the ic and the short still remains . i tested the other ones on the board and there is not short to pin 4&5. When i took a look at schematic these pins do not correlate. I tested everything i could with a multimeter and cannot find this short. Just found the schematic again and will get back to it tommrow. I posted a pic of the circut for q1661 sc page 3/4 .Comment
Nevermind, the ic i removed is ic1920 and pin 4 and 5 are linked together. C691 right before q661 gets a charge becase it has a nice arc when discharging. My multi meeter cannot read 30g123 or rjp6065 and my lcr broke.
I did read them to be real before it broke . i had 1 out of 10 30g123 read good and the rest as capacitor.Last edited by bman4; 01-11-2019, 11:17 AM.Comment
im getting 195v on the gate without the rjp6065 in circut.i did forget to put ic1920 back in. The 220v circut must be shorted to the gate. This must be wong shouldent parts be burning up. Might be - 195v ireuploaded the service manusl for easy access.Last edited by bman4; 01-12-2019, 07:16 AM.Comment
I forgot to mention the diodes i replaced. D652,d865 replaced with a random 888A because at that time i figured a diode is a diode. I replaced them negative to collector like the rest i see on board. Next i removed d673,d674 because i thought they where the short. I did not have schematic and figure negative to collector. When looking at the schematic i believe its positive to collector for d673,d674. Im gonna look over the schematic to try and figure out polarity and order the proper diodes.Last edited by bman4; 01-13-2019, 07:14 PM.Comment
Seems as though I have one of these with a severely wasted panel.They call me......."threadkiller"Comment
I haven't even looked at it yet, other than plugging it in and giving it a (no) go. Had it for 3 months. I don't think badcaps.net allows sales on or through the forum.
Eventually I do intend to part it out, just been busy with repairs.They call me......."threadkiller"Comment
Mine is a TC-P42X1They call me......."threadkiller"Comment
Mines the 1080p version,it's why i want to spend the time to repar it. I wonder what the diffrences in sc boards are. I know i can probly fix mine but its been 4 moths wating on parts and failures. Im about to give in and buy one!Last edited by bman4; 01-17-2019, 12:44 AM.Comment
My diodes where all in proper poliarity. Im getting the same voltage reading from cap 813 big black 220v.at bottom. I get conunity from ic784 pin 6 / positive of cap 813 to emiiter of q661 but not collector or anywhere else. I get the same voltage on emiiter and collector negative - 195 testing from chassis. I used a rf101l4s diode at d652, d865. I removed removed them and voltage still remains.Comment
pin 6 of ic784 mip9l02. Pin 9 is gnd that has conuninty to emitter of q661. So maybee its.the culprit. My dirst.test.i messed up.and forgot to connect ac to buffer clips and got arcing. I remeber when i did this to another it blew a ic like this up bur was shorted unlike this. This also has 195v between source and ground but not negative 195 getting 400v from gnd to drain with leads to 250v cap. Source has conunity to chassis gnd but i think its threw coil L897 and reads 1.5 ohm. I get 0.0 from gnd of ic784 to emitter of q661.Last edited by bman4; 01-18-2019, 10:54 PM.Comment
by stecosHi everyone!
For my passion for technology I'm now collecting several... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... -
Assuming...7 Photos -
by SACRI need Schematic A-Board @ Mainboard for Panasonic Plasma TH-P42X28K. Code : TNPH0842. I want to replace 1 MLCC but I don't know values (capacitance & voltage) & codes. Can someone help me? Thank you...11-20-2023, 11:53 PM
- Loading...
