Sharp Aquos LC-C3234U blinking power/OPC lights
    I recently picked up a Sharp Aquos LC-C3234U to fix up from the local thrift store (it's my form of doing puzzles). TV won't turn on when power is pressed. TV immediately shuts off when power is pressed, followed by repeating lights. Power light and OPC lights blink once together, then just power blinks once, and then it repeats. Service manual online doesn't really give any good info, but other Sharp SMs say that the power blinking twice means its a power supply issue. Can't find any schematics.
    Now, I'm pretty sure I found the problem on the board. I looked for shorts on the power supply and found what I think is a shorted MOSFET. When applying my DMM to the source and drain, it shows almost 0 ohms. This is all in-circuit testing, which I know it's not the best thing to confirm problems, but the only other thing that could cause the low resistance is a disc capacitor that's in parallel with the source and drain. Not trying to say it can't be the cap, but I think the MOSFET is more likely the culprit.
    It has K4096 written on it. Here's the data sheet: https://cdn.badcaps-static.com/pdfs/...38d25e7a39.pdf
    My question is: Digikey doesn't have this MOSFET in stock (says obsolete), and the only place I can find any for sale is eBay, where the two on there ship from either China or Malaysia. Is there an equivalent MOSFET I can buy and use instead?
    Thanks!
    Re: Sharp Aquos LC-C3234U blinking power/OPC lights
    You should desolder that mosfet and confirm it is shorted. If it is bad, you have to desolder it anyway.
    I have been fooled more than once with in circuit readings despite my best efforts.
    Chat or send an email to digikey. They have live useful folk who can help finding a suitable replacement. Feedback from others who have done this in the past say service is great.
    --- begin sig file ---
    --- end sig file ---
      Ya, that's a good point. I haven't had the time until tonight to really take a good look at the power supply. I'll try desoldering and testing in the morning.
      Thanks for the tip. I just got done talking to one of their tech support people. They said that while they don't have a direct cross reference to the K4096, they said that this part is the closest match: http://www.digikey.com/scripts/dksea...ywords=AOT8N50
      The Digi-key person said that this MOSFET is like an upgraded version of the K4096. I see that most of the numbers match up or are better (the ones I can understand and think are important like Drain to Source Voltage and Current Continuous Drain), but terms like gate charge and input capacitance are a little different and I'm not familiar with those terms.
        That is great service for a midnight call on potentially a 95 cent item.
        Sorry, I can't help with all the technical specs.
          I can't see a problem with that suggested replacement.
