Philips 46PFL8000 power supply failure
  • ALEKS
    • Mar 2013
    • 4
    • SLO
    I own Philips LCD 46PFL8000.
    It looks like there is a problem with power supply.
    The fuse is Ok. The power suppy is completly dead.
    I have measured all resistors and diodes and they looks fine.
    The TV is only 4 months old so the caps are fine, they looks fine too.
    I think that the problem is Q601 it has 300V on PIN2 and nothing on PIN 1 or 3
    If you can help me, or send me a schematic, I would be very glad.
  • selldoor
    Slow Learner
    • 7870
    Re: Philips 46PFL8000 power supply failure
    If the TV is less than 12 months old it should be replaced under warranty?
    • ALEKS
      • Mar 2013
      • 4
      • SLO
      Yes I know, but we have holiday in monday and I have time.... nothing to work, no tv
      • ALEKS
        • Mar 2013
        • 4
        • SLO
        anyone ? Please
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Moved from FAQ.
          sigpic
          (Insert witty quote here)
            by sam_sam_sam
            07-01-2024, 06:34 AM
            DVR camera recorder switching power supply capacitor failure really
            by sam_sam_sam
            These cheap non brand capacitors at it again
            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
            Well at least I have the cameras back on line I to try the...
            01-22-2022, 06:28 PM
            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
            by sam_sam_sam
            I was working on this CNC machine today found no keyboard functioning no control relay powering on
            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
            Found shorted diodes on main controller relays there are 3 of them that...
            01-07-2023, 05:43 PM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
