I have this TV that takes a while to turn on, I found three 10V 1000uF caps that are bulged and leaking. I have available a couple of TV parts that have two 16V 1000uF and a 25V 1000uF so my question to you guys is, can I use the combination of 16V and 25V caps in place of the 10V caps?
Magnavox lc32sl1
Re: Magnavox lc32sl1
The main thing is that it has to be low ESR type cap (such as PANASONIC FM/FR/FC series) since it is used in the hi frequency power supply. You can use what you have right now just to try it out to see if the TV will function then you can order the right type, general cap will not last in switching power supply.
That 10V 1000uF is for the 5V power supply for running the main board.Never stop learning
BUDM do you consider Panasonic caps the best? My second question to you is, I have ordered low impedance Nichicon caps from mouser, I have been told low impedance = low esr, yet I can find those same caps at digikey and they will state that the caps are regular usage caps. So is low esr the same as low impedance?
Capacitor ESR is not the same as Impedance. Impedance is more complex measurement of the caps.
You can learn more by Google "what is impedance rating of the capacitor"
I.E.
I cannot say which brands are the best as far as Japanese made caps are, but I have very good records with PANASONIC caps. I am sure the NCHICON low impedance will be fine. You can compare the spec of the PANASONIC and the NICHICON (depends on the series).Never stop learning
"If it fits, I sits."
Cap diameter/size isn't important other than getting it to fit.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yeah, I have seen that often. If unsure, look at the datasheet for low esr or low impedence.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Give us a link to one that you are looking at - there is usually another column for ESR but its not always populated - try the data sheetPlease upload pictures using attachment function when ask for help on the repair
HZ is "too" good. They are designed for computer motherboards; a power supply may not work well with them. The other two are good.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
It will probably work. The problem is, some power supplies may not work with it, so I suggest FM/FR/FC as they work with virtually every power supply.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
