Hi guys question on buffer board
  • davewilson61
    • 110
    • usa
    got a 50" samsung plasma tv
    tv comes on no picture
    found 1 bad chip on the upper buffer board (fried)
    even if i unplug this upper buffer board should i have a picture on the lower half of tv?
    i dont.....
    lower buffer board has no shorts to ground asumming its good
    could my y board be bad? any way to check it?
    if i just order the bad upper board and replace it would it be Fried from the y board if it was bad?
    thanks dave
  • rayrod81
    • Oct 2010
    • 205
    Re: Hi guys question on buffer board
    Most of the time on Samsung plasma TVs a bad buffer will take out the Y-main board. Sometimes it does not happen but generally it does. When you unplug the upper board on a Samsung you will not get a picture but the screen should light up and just show a black screen on the lower half. If it does not light up then the Y-main is toast. It is very likely that plugging a good upper buffer in to the Y-main will just fry the board immediately. In most cases you will need to repair the Y-main and replace both buffers. Even if the lower buffer tests good it may just be a matter of time before it fails. What is the model number of the TV? That info will help us help you.
    • anomaly
      • Dec 2012
      • 18
      • Us
      A bad Y-main board will be the cause of that one bad chip on the buffer. Remove and check all of the mosfets on the y-main, at least one of them will be shorted.
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
