LE32A558 vertical bars and line
  • albertocastillo2001
    • Mar 2013
    • 19
    Hello
    I own a Samsung LE32A558 TV for a bit more than 3 years (warranty expired after 2 years) and since then I've been getting these strange vertical lines on the left side of the TV, their size is around the difference of a 16:9 and 4:3 image on the left side.
    Most of the time that vertical rectangle turns into different colors, like based on the background of the rest of image.
    Here you can see 2 photos: http://www.mediafire.com/?9glba6k50t4iw
    One of them is the thin green vertical line
    The other one are the vertical bars, they are white and black now but after a few minutes they begin to switch colors
    They got used to get removed after 20 mins of use, but now a green vertical thin line shows in the screen, it's almost not noticeable tho
    A few days later my TV displayed 3 more lines next to the green one. 2 are black and one is red. Apparently now I only get the green one
    TV has been updated to the latest firmware and reverted to default state
    According to the documentation I read in this forum and several other sites I really doubt the inverter or the power supply are the problem.
    So I suspect of the T-CON, main board and the LCD panel (this one being the most expensive at all)
    I found a service manual for this model but it doesn't seem to contain much info about my problem
    I can post a video of the failure as well
    I haven't got any knowledge in LCD TVs except the one I learned on the net, videos and this forum
    Thank you.
    • Mar 2013
    • 19
    Re: LE32A558 vertical bars and line
    Hello
    Any help you can provide me?
    I forgot to put brand name in the title but it doesn't let me to edit it now.
      It is probably a defective panel. There's the chance it is a tab bond problem; see here for a potential fix.
      https://www.youtube.com/watch?v=xHst6pKLtTE
      Note the symptoms of tab bonds vary greatly, but the fix is the same.
        • Mar 2013
        • 19
        That's interesting.
        Is that connected from the T-CON card to the panel?
        However is a bit risky to test it for me while the TV is on (shock risk) These TVs get high voltages as far as I know
        Do you suggest me to attempt this anyway or take a look at other things as well? What else could be failing looking at the symptoms?
        Thanks!
          The voltage on the LCD panel does not exceed 30V, which is non-hazardous. As long as you do not touch the PSU or backlight connectors there should not be any hazard.
            • Mar 2013
            • 19
            Hello
            Sorry to revive this topic. I took a lot at my TV for the problem, but couldn't access the T-CON tab, because it's under a metal shield with 4 scres, I tried to remove them but it won't come out.
            I was able to check the LCD ribbon tabs. Apparently those are the failure of the TV. I didn't check them with the TV turned on because I am not an expert and I am quite afraid of getting electrocuted if I accidentally touch the power supply or the inverter board.
            I checked the video one year ago and that seems like a cool solution. But I wonder, isn't there a better method like maybe some kind of good sticky tape? Wouldn't it work as well?
            Thanks!
              If you are only touching those tabs and nothing on the power supply, you will not get electrocuted. No worries there. The ribbons need to have pressure applied on them to diagnose, and for a permanent fix. You can try a reliable form of applying pressure, the most commonly seen is the "shim" of thermal/foam material which presses down. But you can use almost anything, really.
                • Mar 2013
                • 19
                Hello
                Thank you, any examples I can see?
                  Those videos show the method I use myself...
                    • Mar 2013
                    • 19
                    Oh, I saw the one using silicone tubes.
                    Any recommended brand, model of doubled sided sticky tape?
                      I've always used the cheap discount shop stuff...
                        • Mar 2013
                        • 19
                        Haha, ok, thanks
                        I asked because I have tried to use duck tape on electronics and it always became loose so maybe I didn't pick the right ones or not good brands..
                          • Mar 2013
                          • 19
                          A few more questions.
                          According to the video, the latex tube method seems to work best. Foam or thermal don't work that well?
                          In case there were more than one or two tabs failing. Is it possible to apply this method to all of them in case it's needed? I assume that over time, some other tabs will fail as well
                          And another question about security. Power supplies or inverter can still hold a charge even if the TV is unplugged. How can I discharge it? Shorting the power plug cable pins when it's unplugged from the wall?
                          Thank you!!
                            You will face no shock hazard from the PSU or inverter if you do not touch them.
                            Also, the set HAS TO BE POWERED while doing the test to see if it is a tab bonds fault.
                            Otherwise, you cannot find where the fault is. So discharging or unplugging the set will not work.
                              • Mar 2013
                              • 19
                              Oh, sorry, maybe I didn't explain myself properly.
                              I meant when dissasembling the TV or doing repair
                              Thanks!
                                • Mar 2013
                                • 19
                                Hello
                                I know this is old, but I took so long on dissasembling it due to an illness that has been following me for years. I am better now, althought not well enough. So I apologize to everyone trying to help me
                                I dissasembled it again yesterday (it's still open) and correct, the leftmost ribbon tab is defective. But there's another problem, the black vertical line won't ever dissapear.
                                I uploaded a video where you can see the line and me tuching the tabs.
                                I also tried to disconnect both sides of the T-Con board, and the line seems to be always there.
                                Panel model is: t315hw01
                                The video is here: http://www.mediafire.com/watch/7cuok...214_223324.mp4
                                Thank you!
                                • cubytus
                                  Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                  by cubytus
                                  Hi to all,
                                  I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                  I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                  Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                  01-10-2024, 01:26 AM
                                • hoot
                                  One vertical green line on my AQUOS LC-70LE740E TV
                                  by hoot
                                  on my AQUOS LC-70LE740E LCD TV there is a vertical green line on the screen. (pictures below)
                                  Does anyone know what the issue could be?
                                  Up close it looks something like this.
                                  Can this fault be serviced?
                                  What I want to do is the following:
                                  gently pressing on the ribbon connections along the top and bottom of the panel in the area of that line. Pushing a driver IC onto the flex cable it sits on to restore the lost connection. When the problematic area is found installing...
                                  11-21-2021, 07:48 AM
                                • TrueSword88
                                  Kogan - KALED65XU9220STB - Blue Vertical Line
                                  by TrueSword88
                                  Hi all.
                                  I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                                  The line just happens to coincide with the end of COF and start of the next COF (attached).
                                  The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                                  Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                                  Hoping to fix...
                                  05-05-2023, 04:28 PM
                                • almarhum
                                  To fix laptop screen vertical line by working on its EDP cable
                                  by almarhum
                                  Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                                  As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                                  05-07-2024, 02:12 PM
                                • mrsith
                                  Samsung UE58TU7100K - no picture, vertical line
                                  by mrsith
                                  Hi.
                                  Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                                  This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                                  Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                                  02-07-2023, 11:18 AM
