Samsung LE32S62BX probably power supply
    Re: Samsung LE32S62BX probably power supply
    Do you mean the reading is on the IC PIN 8 and the ground pin, or you are measuring the pads where the IC is (empty pads with the IC removed)?
    • Kabbone
      • Mar 2013
      • 19
      On the pins of the IC, removed from the pads
      • Kabbone
        • Mar 2013
        • 19
        So, I replaced ICM801 and QB802 isn't getting hot anymore. VCC is now switching between 0 and 15V. TV is still not working... I'm waiting for ICP801S now.
          The startup capacitor could also be bad, especially if the hot transistor next to it damaged it.
          • Kabbone
            • Mar 2013
            • 19
            Finally all parts arrived, but it's still not working. The code of the power LED is 5 short and 1 long, perhaps someone can interpret this code. I don't really know how to continue on this now.
              Transistor still hot?
              Samsung do not use blink codes, ignore that for now.
              All voltages from PSU good or bad?
              • Kabbone
                • Mar 2013
                • 19
                Transistor keeps cool now. I will check all voltages later or tomorrow
                • Kabbone
                  • Mar 2013
                  • 19
                  The output voltages (12V, 24V,...) are all still bad. Vcc is 15V for about 2-3 sec and then switches to 0V for also 2 sec, it's always an up and down. I can hear a very quiet "click" when it comes up again.
                  • Kabbone
                    • Mar 2013
                    • 19
                    PC801S and QB851 are switching, but the ON/OFF Signal is switching, has anyone one more suggestion?
                      If the ON/OFF is switching you may have a main board fault, assuming all voltages from the power supply are good.
                      • Kabbone
                        • Mar 2013
                        • 19
                        Ok, the voltages are bad. For example at TB801S I got at Pin 2 about 380V but nothing at Pin 8-10. How is this affected of Pin 5-6-7?
                        • Kabbone
                          • Mar 2013
                          • 19
                          I bought a used board now and the TV works again. Does someone need some spare parts? :P
                            09-07-2024, 05:50 AM
                          • cheeky2
                            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                            by cheeky2
                            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                            06-15-2025, 05:12 AM
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                          • alltvrepairs
                            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                            by alltvrepairs
                            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                            Any one met this problem in the past?...
                            10-08-2025, 07:34 AM
