Got this TV for next to nothing as a non-working clearance item that had been returned to the store TWICE! I was able to get it turned on a couple of times but usually it would just be stuck and non-responsive at the orange vizio light. It was classic eeprom failure on the vizio "ExxxVO" series of TV's. I bought an SO-IC eeprom off of eBay for $20 and after a delicate soldering job it now works perfectly. If you have one of these and decide to go this route you will need good magnifying glasses and a fine pointed soldering tip. Not a repair for the faint hearted or if you aren't pretty comfortable soldering.
Vizio e421vo orange light but won't turn on - eeprom
Hello Everyone!
I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died....06-28-2025, 02:57 PM -
by mosfetratusWhen i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
Works with battery and charges, but when i shut off i get this problem.
It had liquid spill. Board has no corrosion, keyboard is working, power button... -
by TomyleeHi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
Here's what I've observed:
All ribbon cables are properly connected
Battery is present and in good condition
No reaction even with screens disconnected
There's a visible burn mark / overheating sign on the metal shield, right above the CPU
I’m suspecting an issue with the CPU, PMIC, NAND, or a power...3 Photos -
by jheunnei have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
in first image there is 0v out for lcd
https://ibb.co/5XppmpkH
in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
https://ibb.co/fdJkbJs8 -
by RezendesHello, I have a MacBook 820-3115-B board that never shows an Orange light and goes straight to a green light and turns itself on when the ac adapter is plugged in. System won’t run off battery and turns off immediately when ac power unplugged. I believe the battery should be ok as it was a replacement not too long ago but it’s possible that’s the issue as most anything is possible I guess. I don’t have any spare batteries or donor boards although I have ordered 2 on the way. I have replaced U7000 and same results. I have also applied flux and reflowed the SMC IC and no change. Nothing...
- Loading...
