philips LCD tv.42PFL5603D / 10
  • soukehal
    • Dec 2012
    • 45
    • Algerie
    Hello hello to all.
    problem on a philips LCD tv.
    Model: 42PFL5603D / 10
    It is a model with only two cards visible.
    The Power Supply card, which includes the inverter. Only two to neon.
    The default is:
    The image is displayed for a few seconds, then dark spot in the middle of the image and slightly less dark bords.Puis on this spot covers almost the entire screen. Appears when I press this task a little on the right side screen everything becomes normal after about 5 to 10 minutes, the dark spot back, I think is a problem neon "tired" request ugly thank you in advance.
    seeks to remove lcd screen instructions.
  • soukehal
    • Dec 2012
    • 45
    • Algerie
    Re: philips LCD tv.42PFL5603D / 10
    bonjour,c'est résolu,sujet doit être fermé
    hello, this is resolved, subject must be closed
    • pat0te
      Tv Philips 42PFL5603D/12 random fail
      by pat0te
      Hi to all! first post here, awesome forum. Greetings from Spain. I'm a electronic technician but I forgot many things because I was working in IT all my life :-)
      I got a TV Philips 42PFL5603D/12 (chassis SQ522.2E LA) without remote control and no history to follow.
      TV has random failures. Sometimes, stucks in a rebooting loop showing white led and video and audio signals, then fixed red light (stand by?) for some seconds, then red light goes off and white light come again with video and audio showing just fine. This rebooting stages, has random working times.
      Another...
      11-19-2022, 08:09 AM
    • Cabbar
      Philips 42pfl5603d Noise
      by Cabbar
      Hi! For almost a year now, a 13 years old Philips 42pfl5603d LED TV has been making high-pitched and loud noises from the standby light's back location (right bottom) when it's turned on for the first 5-10 mins. It is only connected to a laptop via HDMI.
      During that initial time, the noise flactuates if the screen changes and lighter colors seem to increase both the pitch and the loudness. After approximately 10 mins, the sound turns into a weak buzz, and if I turn it off and back on, it's as if it has no issues.
      When the problem first began, if I turned it off and on...
      10-04-2021, 11:47 AM
    • G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
      by G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
      It does power up when pressing the power button.
      I already try the power button while plugin the plug with no result.
      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
      Could this be an PSU or eMMC issue ?
      07-19-2025, 03:43 AM
    • spleenharvester
      Reverse engineering of DoCreate DHJ567 handheld spot welder
      by spleenharvester
      Hello everyone
      I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
      Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
      05-08-2025, 02:52 PM
    • aidanmo
      Philips 43PUS7506/12 - Loud blown out sound
      by aidanmo
      I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
      I thought maybe the speakers got damaged, so I replaced them - no dice.
      • Using the internal speakers, it always happens.
      • Using the headphone jack, it never happens.
      • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
      02-28-2025, 03:13 PM
