philips LCD tv.42PFL5603D / 10
  • soukehal
    • Dec 2012
    • 45
    • Algerie
    Hello hello to all.
    problem on a philips LCD tv.
    Model: 42PFL5603D / 10
    It is a model with only two cards visible.
    The Power Supply card, which includes the inverter. Only two to neon.
    The default is:
    The image is displayed for a few seconds, then dark spot in the middle of the image and slightly less dark bords.Puis on this spot covers almost the entire screen. Appears when I press this task a little on the right side screen everything becomes normal after about 5 to 10 minutes, the dark spot back, I think is a problem neon "tired" request ugly thank you in advance.
    seeks to remove lcd screen instructions.
  • soukehal
    • Dec 2012
    • 45
    • Algerie
    Re: philips LCD tv.42PFL5603D / 10
    bonjour,c'est résolu,sujet doit être fermé
    hello, this is resolved, subject must be closed
    • pat0te
      Tv Philips 42PFL5603D/12 random fail
      by pat0te
      Hi to all! first post here, awesome forum. Greetings from Spain. I'm a electronic technician but I forgot many things because I was working in IT all my life :-)
      I got a TV Philips 42PFL5603D/12 (chassis SQ522.2E LA) without remote control and no history to follow.
      TV has random failures. Sometimes, stucks in a rebooting loop showing white led and video and audio signals, then fixed red light (stand by?) for some seconds, then red light goes off and white light come again with video and audio showing just fine. This rebooting stages, has random working times.
      Another...
      11-19-2022, 08:09 AM
    • Cabbar
      Philips 42pfl5603d Noise
      by Cabbar
      Hi! For almost a year now, a 13 years old Philips 42pfl5603d LED TV has been making high-pitched and loud noises from the standby light's back location (right bottom) when it's turned on for the first 5-10 mins. It is only connected to a laptop via HDMI.
      During that initial time, the noise flactuates if the screen changes and lighter colors seem to increase both the pitch and the loudness. After approximately 10 mins, the sound turns into a weak buzz, and if I turn it off and back on, it's as if it has no issues.
      When the problem first began, if I turned it off and on...
      10-04-2021, 11:47 AM
    • alro7779
      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
      by alro7779
      Hello, guys!
      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
      09-14-2025, 12:25 AM
    • G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
      by G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
      It does power up when pressing the power button.
      I already try the power button while plugin the plug with no result.
      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
      Could this be an PSU or eMMC issue ?
      07-19-2025, 03:43 AM
    • double_DD
      Philips curling iron - is this a common AC cable?
      by double_DD
      Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
      As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
      Not sure if this is something Philips proprietary, or a standard, but the cable plug...
      08-18-2025, 10:04 AM
