Vizio E420VO - HDMI BLOWN AND BURNED - WOW
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    This is the first time I have ever heard of this. So I find this TV on CL for only $25. The guy tells me that Verizon was out hooking up his FIOS and SNAP... the TV is dead. Verizon ended up replacing the TV with a better one by the way. So... I get it home and open it up to find the scorched HDMI port. The shocking part to me is how bad it looked. I havent looked at they pinout or schematics for HDMI but how much voltage is going through this damn thing? I mean it cooked pretty nice. See pics.
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Vizio E420VO - HDMI BLOWN AND BURNED - WOW
    My guess is there was some sort of fault in isolation of mains in at least 2 appliances.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      I'm gonna try to fix this board or the board that I got off of ebay - AS IS/NON WORKING board. There are some working boards on ebay for sale but they are to pricey. I hope it's just a regulator on the board that I'm getting cause I dont want to try to replace parts on the burned board. I dont trust it even if I got it going.
        You can probably lift off that HDMI IC and find the TV will work without it, minus HDMI of course. I would guess the protection diodes are short so it is shorting out one of the rails.
        • tieny
          • Feb 2012
          • 478
          Had a 37" vizio lcd tv that also had the HDMI ports burnt just like that!
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            One of the first things that I checked on this burned board was the two fuses at the input and found one to be blown. I didnt spend that much time on it yet to know which one. I could try replacing some parts just for the hell of it. I have other main boards with good HDMI ports to swap out. I will check the diodes too. There is an eight pin surface mount chip that looks to be one for each HDMI, what are these usually? Seen in pic #2
            • johnboy1313
              • Nov 2012
              • 1959
              Looks like Verizon should be happy that it didn't burn the guy's house down. Yikes! Do you think the other main board is an EEPROM issue?
              • Dgtech
                E. Technician
                • Apr 2009
                • 1462
                • Steeler
                I hope it's something simple that I can swap out. I can do some surface mount stuff but not the real small crap.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  I had the exact same set with an EEPROM issue. If I remember correctly, when plugged in the Vizio logo would light amber but there was no response from the power button. I sent the mainboard to be repaired. It cost $50 plus shipping. You can buy the pre-flashed EEPROM for $20 if you think you can do it yourself.
                  http://www.ebay.com/itm/Vizio-E420VO...-/140921475866
                  Have you tried the AS-IS main board in the set to see the symptoms?
                  • Dgtech
                    E. Technician
                    • Apr 2009
                    • 1462
                    • Steeler
                    I still have about two days left in the ebay auction.
                    • SFGiants
                      • Jul 2015
                      Only way to smoke like that is for the Verizon source and the TV to be on alternate legs of the main AC. (split 220 to two 110V)
                      As stated the HDMI path is likely stressed and Vizio does little to protect these inputs.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4979
                        • New Zealand
                        It's goneski!
                        -David VanHorn
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Very likely a bad neutral issue in the house wiring, and they hooked FIOS up, and the fios equipment was the ground/neutral for some reason ... a lot of current went through the HDMI connector housing and burnt it up. Same thing can happen with regular coax.
                          Muh-soggy-knee
                            • 31087
                            actually connecting the cable while both units are powered could do it.
                            this problem has pissed me off for a very long time after almost getting thrown off a ladder while working on a sat dish.
                            item #1 has a switching psu and no ground reference.
                            so the difference between gnd and the power rail is 5v or 12v
                            item #2 has a switching psu and no ground reference.
                            but the difference in ground between the 2 items can be equal to rectified mains!!!
                            ever plugged a video cable into something and seen little sparks ??
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              What you're talking about is due to the Y type caps.
                              The current that those can pass is NOT anywhere near enough to cause this kind of damage to a PCB!!!!!!!!!
                              Muh-soggy-knee
                                Yes. And the shield of the connector is always connected to the TVs reference ground on the chassis and PCB. By design this should make connection first. This causes the small spark. But should be OK after that as they are now equalised with each other.
                                This kind of fault looks like a power surge or complete isolation failure in one device. Scary.
                                • cmlewis89
                                  LG 47LB5DF blown power supply board
                                  by cmlewis89
                                  Hi folks,
                                  I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                  09-03-2024, 07:50 PM
                                • mrtek
                                  Vizio M65-C1
                                  by mrtek
                                  Hi.
                                  picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                  When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                  This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                  07-14-2025, 07:28 PM
                                • mikey5791
                                  Need help to replace burned resistor in 350w atx psu
                                  by mikey5791
                                  Hi to all forum members,
                                  Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                  The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                  Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                  Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                  12-26-2024, 04:55 AM
                                • howardc64
                                  Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                  by howardc64
                                  Failure Symptom
                                  No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                  Where is the short?
                                  Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                  Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                  05-27-2025, 02:56 PM
