baird lcd tv no backlight
  • shaunbt123
    • Nov 2012
    • 119
    Hi there to everyone,just wondering if someone can help me ,i have a baird 42 inch lcd tv model no-cn42bair.the green power light will come on as normal,however there is no backlight ,there is sound,i have tested the outputs on the power supply which are all giving out 0v except the 5v pin,but if i unplug the inverter board the voltages return to normal ie 12v and 24 v,also if i unplug the inverter i can see images on the screen with a torch. i cant see no bulging caps on power supply,i have tested the three caps on inverter board with esr meter all three were good.
    thanks in advance.
    shaun.
    Re: baird lcd tv no backlight
    Can you check across the inverter board capacitors for resistance, with the board unplugged? If the resistance is low, the inverter board probably has a short.
    • shaunbt123
      • Nov 2012
      • 119
      thanks for your reply. can you explain to me where i need to test for resistance ie where to put the test probes,sorry to sound dumb but as you can see im not an expert,i did test the caps with esr meter and it said they were ok.
        Set meter to 200 ohms (the horseshoe symbol if present.)
        Across any one the caps on the inverters you tested, measure resistance. Power to the TV must be disconnected.
        Report the reading you get.
        • shaunbt123
          • Nov 2012
          • 119
          thank you ill test the resistance of the caps later,ill get back to you later with the readings.thanks again.
            It's more of a test of the entire inverter rather than the caps.
            • shaunbt123
              • Nov 2012
              • 119
              hi again.with the meter on the 200 ohms setting, im getting the following
              i tested all three resistors seperately and all show 0.62 ohms this is with the board disconnected from tv.
              thx again for the help.
                Seems to be shorted. Just to be sure though, can you show me what range you had your meter on?
                • shaunbt123
                  • Nov 2012
                  • 119
                  hi again heres a pic of the setting i had the meter on.
                    That's the correct range. When you touch the probes together, what do you see?
                    • shaunbt123
                      • Nov 2012
                      • 119
                      if i touch probes together im getting
                      00.5
                        And you get 00.62 or 00.6 or 06.2 across inverter? Just trying to figure out the extra digit.
                        • shaunbt123
                          • Nov 2012
                          • 119
                          ive checked again for you. heres the results
                          00.5 with probes together
                          04.2 across inverter
                          thx.
                            4.2 ohms is definitely bad, does it rise or change at all?
                            • shaunbt123
                              • Nov 2012
                              • 119
                              it just stays at 4.2 ohms
                                OK, so I would suggest either a repair or replacement of the inverter board. Repair would likely involve replacing all MOSFETs plus perhaps the driver IC and would cost around £15~£20 to do it yourself. Replacement prices vary.
                                • shaunbt123
                                  • Nov 2012
                                  • 119
                                  i have found a replacement part for around £24 so im going to order that,when i have fitted it ,ill let you know what happens.
                                  thank you again for your help.
                                  • shaunbt123
                                    • Nov 2012
                                    • 119
                                    Hi tom
                                    just to update you.I got the new inverter board today and it worked a treat,i now have a fully working tv,so you were spot on when you said the old one was shorting out.
                                    thanks very much for your help.
                                    Just as a matter of interest what would the resistance across the caps have been if the board was ok.
                                    shaun.
                                      Nearly infinite; >2kohm at the very least.
                                      Glad to hear it's working!
                                      • TVGUY101
                                        • Mar 2015
                                        • United Kingdom
                                        heyyy can anyone tell me what is wrong with my tv please ????? all the colours have gone like this this morning and i need to replace what has gone wrong!! MAKE, Baird, MODEL, CN42BAIR
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • jimbofz
                                          lg 32LC46 backlight inverter board fault
                                          by jimbofz
                                          Hi this oldie had no backlight .after replacing caps on 24v rail ,
                                          still no b/l this uses inverter type:1315 B1-16A,
                                          im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                                          all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                                          this allows protect to be temporary overridden.
                                          b/l now comes on
                                          but the left hand side of pic is gradually darker than the right side
                                          i have the cct for the tv
                                          but it does not have inverter cct.
                                          i opened it up to inspect the ccfl tubes
                                          and they dont have any...
                                          12-19-2021, 06:58 AM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
