PDP-R03U Pioneer Media Receiver Problem
  • jamlegend
    • Mar 2013
    • 7
    I have a 50" Pioneer TV (Old school one) with a PDP-R03U receiver. When I got it, it has the dreaded E01 error which I fixed by resoldiering the power supply board. I has been working fine for 6+ months but now I get a red hue across all video inputs. The menu does not have this red hue and occasionally it goes away when I turn the TV on but comes back after 10-15 seconds. It's not the panel because if I hook up a DVI cable directly to the plasma panel leaving out the media box, the image is great.
    This is a great TV and I would hate to have to get rid of it. Any ideas as to why the screen has this red hue color?
    Thanks,
    Re: PDP-R03U Pioneer Media Receiver Problem
    My first place to look would be a connector cable between boards. In LCD and plasma TVs, a loose cable can cause a variety of coloured hues; the same may apply to your media box.
    • jamlegend
      • Mar 2013
      • 7
      Tom66, Thanks for that speedy response. I'll reseat all the connectors and let you know what happens.
      • jamlegend
        • Mar 2013
        • 7
        I reseated the connectors with no change...still have the red hue. It seems it could be the video processor that takes the inputs because all the TV menus are clear. Any other ideas?
        • jamlegend
          • Mar 2013
          • 7
          Another tidbit of information, the video is sent to the box via component cables. If I unplug the green, the image goes away. If I unplug the red or blue (while the other two are plugged in), the image changes to more of a grey scale. Is this what is supposed to happen?
            Does the media box support other inputs? Have you tested those?
            • jamlegend
              • Mar 2013
              • 7
              It does and I've tested those with the same results.
                Is it a red hue (overlaying on top of all pixels) or just only letting through red?
                You can test this on a black scene: Is it red or black?
                Then try different colours.
                • jamlegend
                  • Mar 2013
                  • 7
                  blacks seems to look black and the red hue is not very strong it's just that the non red colors do not look right. Even the white area, you know it's supposed to be white, it just has a tint of red to it.
                  About the component cables, is it nomal for the entire screen to go black when you unplug the green line?
                  Thanks,
                    This could be a cold/dirty solder joint.
                    • jamlegend
                      • Mar 2013
                      • 7
                      That was also an idea I was thinking about. Do you think it's on the power supply board vs. the video processor board (I may not be using the best terms here)? Outside of cracks in the solder, is there another way to check for a cold solder?
                        I would think the video board myself. Cold solder joints can be found by heating up parts of the unit, e.g. using a hairdryer.
                        • pulper111
                          Pioneer VSX-1123 Receiver - weird voltage problem
                          by pulper111
                          Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
                          I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...
                          09-02-2020, 11:12 AM
                        • theone111
                          by theone111
                          3. Problem: TV shuts down
                          07-22-2024, 10:36 AM
                        • matpod16
                          Pioneer VSX-D1011 - turn on problem
                          by matpod16
                          Hi all! I have a problem with Pioneer VSX-D1011 – it don't turn on when the amplifier is disconnected from the socket for a few minutes. Standby LED doesn't light up. I'm a beginner in electronics, so I'm not very good at reading schematics. I tried to find the visual damages of components but I didn't see anything wrong. All of the fuses are ok, both of the switches the same. Have you any idea where should I start looking for? Once on every 100 tries I am able to turn it on, but what can it depend on?
                          09-07-2023, 01:43 PM
                        • CDNBrewer
                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                          by CDNBrewer
                          Hello Everyone,
                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                          Symptoms:
                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                          • I swapped the Left and Right surround
                          08-05-2025, 09:29 PM
                        • ahmedtou
                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                          by ahmedtou
                          help me please
                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                          I will share all the details with you, including the disc information.
                          Code:
                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                          Current Profile: BD-R
                          Disc Information:
                          Status: Empty
                          State of Last Session: Empty
                          Erasable: No
                          Free Sectors: 12,219,392
                          Free Space: 25,025,314,816 bytes
                          Free Time: 2715:27:17 (MM:SS:FF)
                          Next
                          08-27-2025, 08:49 AM
