PDP-R03U Pioneer Media Receiver Problem
  • jamlegend
    • Mar 2013
    • 7
    I have a 50" Pioneer TV (Old school one) with a PDP-R03U receiver. When I got it, it has the dreaded E01 error which I fixed by resoldiering the power supply board. I has been working fine for 6+ months but now I get a red hue across all video inputs. The menu does not have this red hue and occasionally it goes away when I turn the TV on but comes back after 10-15 seconds. It's not the panel because if I hook up a DVI cable directly to the plasma panel leaving out the media box, the image is great.
    This is a great TV and I would hate to have to get rid of it. Any ideas as to why the screen has this red hue color?
    Thanks,
    Re: PDP-R03U Pioneer Media Receiver Problem
    My first place to look would be a connector cable between boards. In LCD and plasma TVs, a loose cable can cause a variety of coloured hues; the same may apply to your media box.
    • jamlegend
      • Mar 2013
      • 7
      Tom66, Thanks for that speedy response. I'll reseat all the connectors and let you know what happens.
      • jamlegend
        • Mar 2013
        • 7
        I reseated the connectors with no change...still have the red hue. It seems it could be the video processor that takes the inputs because all the TV menus are clear. Any other ideas?
        • jamlegend
          • Mar 2013
          • 7
          Another tidbit of information, the video is sent to the box via component cables. If I unplug the green, the image goes away. If I unplug the red or blue (while the other two are plugged in), the image changes to more of a grey scale. Is this what is supposed to happen?
            Does the media box support other inputs? Have you tested those?
            • jamlegend
              • Mar 2013
              • 7
              It does and I've tested those with the same results.
                Is it a red hue (overlaying on top of all pixels) or just only letting through red?
                You can test this on a black scene: Is it red or black?
                Then try different colours.
                • jamlegend
                  • Mar 2013
                  • 7
                  blacks seems to look black and the red hue is not very strong it's just that the non red colors do not look right. Even the white area, you know it's supposed to be white, it just has a tint of red to it.
                  About the component cables, is it nomal for the entire screen to go black when you unplug the green line?
                  Thanks,
                    This could be a cold/dirty solder joint.
                    • jamlegend
                      • Mar 2013
                      • 7
                      That was also an idea I was thinking about. Do you think it's on the power supply board vs. the video processor board (I may not be using the best terms here)? Outside of cracks in the solder, is there another way to check for a cold solder?
                        I would think the video board myself. Cold solder joints can be found by heating up parts of the unit, e.g. using a hairdryer.
                        • pulper111
                          Pioneer VSX-1123 Receiver - weird voltage problem
                          by pulper111
                          Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
                          I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...
                          09-02-2020, 11:12 AM
                        • theone111
                          by theone111
                          3. Problem: TV shuts down
                          07-22-2024, 10:36 AM
                        • matpod16
                          Pioneer VSX-D1011 - turn on problem
                          by matpod16
                          Hi all! I have a problem with Pioneer VSX-D1011 – it don't turn on when the amplifier is disconnected from the socket for a few minutes. Standby LED doesn't light up. I'm a beginner in electronics, so I'm not very good at reading schematics. I tried to find the visual damages of components but I didn't see anything wrong. All of the fuses are ok, both of the switches the same. Have you any idea where should I start looking for? Once on every 100 tries I am able to turn it on, but what can it depend on?
                          09-07-2023, 01:43 PM
                        • burntonnerings
                          Pioneer VSX-1021 MCACC flashing, can't find problem
                          by burntonnerings
                          Have a Pioneer VSX-1021 that goes to MCACC flashing as soon as it is plugged in.
                          If I enter release mode, it powers on, the screen display is correct, but then it shuts down and goes back to MCACC after a few seconds. I can shut it down to standby (w/o flashing MCACC if I hit the power button as soon as release mode finishes the boot sequence).
                          Entering reset mode and executing a reset doesn't change this.
                          I am unable to enter service mode to see the error counts - Enter + Power button doesn't do anything, whether from normal standby or from MCACC flashing....
                          12-09-2023, 10:11 PM
                        • Zeonalbasta
                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                          by Zeonalbasta
                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                          09-13-2024, 01:17 PM
