Adusting Horiz and Vert size Help!
  • ivtec
    • Dec 2008
    • 1967
    Hi guys I have A Sony Kv36HS500 and i have it connected to the DVI of the PC i have a great pic 1080i but the pic has over scan from the PC is not that bad but i'll like to be able to see the pc controls on the tv on the upper and down edges.
    so i have the service Manual for the tv but i'm afraid to mess the whole thing
    if i post the manaul here can any expert on the matter lead me we precise instructioins on how to adjust the dvi 1080I ,HSIZ and VSIZ i would apreciate.
    Re: Adusting Horiz and Vert size Help!
    If you're slow and careful, and watch the picture while you adjust, little can go wrong.
    • MyHD120
      • 79
      I did this years ago. You have to go to the AVS Forum. Someone wrote a scan program for your computer that allows you to access your video card and make fine adjustments to the overscan. Or you can buy a video card with HDMI out.
      • ivtec
        • Dec 2008
        • 1967
        thanks tom;i have the service manual for Sony kv36HS500 in a Cd i tried to upload it to this forum but it fail cause is to big file,
        i got it from the internet by just googling Sony Kv36HS500.
        what i needed was some good instructions within the service manual.
          I would try adjusting them first. Slowly and carefully while watching the image. CRT experts may be able to add more. I've never repaired one, and only primitively understand how they work.
          • fastvideo
            • Dec 2008
            • 55
            Isn't it easier to adjust the screen size from the PC's video driver?
            I would not do it with the TV, because the screen size will not be the same if you are using this input with other video sources.
            • ivtec
              • Dec 2008
              • 1967
              You maybe right besides on needs a special an hd monoscope,bellow are some instructions for the adjustments,
              2-9.2. 1080i HD MODE ADJUSTMENT
              1. Input a 1080i cross-hatch signal and an HD monoscope signal that
              contains overscan markers.
              2. Adjust the raster position per Section 2-8., only if this procedure was
              not performed for full mode.
              3. Adjust the geometry similar to Full DRC mode. Vertical size is 11.7
              ± 0.1 sq. and horizontal size is 15.6 ± 0.1 sq., if monoscope signal is
              available. Otherwise, set the Vertical size to 91.0 ± 0.6% scan and
              Horizontal size as 91.0 ± 0.6% scan.
              4. Use the following register to adjust the horizontal parameter:
              • MyHD120
                • 79
                I gave you a simpler solution above.
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • dragometin
                  Hitachi 40HYC42
                  by dragometin
                  TV Model: Hitachi 40HYC42
                  Power Supply: 17IPS71
                  MainBoard: 17MB95M
                  Panel: VES400UNDS-2D-NO3
                  When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                  I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                  Is there any variants on 17IPS71 power supply's?
                  UART output pins 10 and 12 on scart connector:
                  Code:
                  12:24:04.595
                  08-08-2024, 05:53 AM
                • disti
                  Flash HP 450 G5 using Arduino - wrong file size
                  by disti
                  I'm trying to flash an HP Probook 450 G5 (2XY63EA) BIOS using Arduino.
                  It's the first time I try this procedure so maybe I'm missing something stupid.
                  I've been able to unsolder bios chip (Winbond W25Q128JV) and wire it up to Arduino.
                  I also dumped it succesfully (dump.bin).
                  Now I'm having a hard time trying to reflash it, because the bios file I downloaded from HP has the wrong size.
                  I downloaded bios from HP (https://ftp.hp.com/pub/softpaq/sp103...0/sp103710.exe).
                  When launched, the executable extracts a file (Q...
                  06-23-2020, 10:09 AM
                • jdczerwin
                  Physical Electrolytic Cap Size Question
                  by jdczerwin
                  My question has to do with through-hole Electrolytic Capacitor physical size and finding the correct specification in ordering a replacement.
                  Example: I'm working on an old video arcade monitor. The parts list calls for two (2) 6800pF, 50V Electrolytic Capacitors (ECap). Based on that specification, you can go to Mouser, DigiKey, etc and get a through-hole ECap at that spec…and get a far smaller one (physical size-wise) than what was on the board.
                  From my limited knowledge, I understand that size does matter in this application because of the stress that the circuit...
                  01-15-2021, 09:08 AM
                  Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                  I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                  I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                  I tested the battery cells there are installed right now and they are testing good with no issues that I...
                  02-04-2025, 08:08 PM
