Adusting Horiz and Vert size Help!
    Hi guys I have A Sony Kv36HS500 and i have it connected to the DVI of the PC i have a great pic 1080i but the pic has over scan from the PC is not that bad but i'll like to be able to see the pc controls on the tv on the upper and down edges.
    so i have the service Manual for the tv but i'm afraid to mess the whole thing
    if i post the manaul here can any expert on the matter lead me we precise instructioins on how to adjust the dvi 1080I ,HSIZ and VSIZ i would apreciate.
    Re: Adusting Horiz and Vert size Help!
    If you're slow and careful, and watch the picture while you adjust, little can go wrong.
      I did this years ago. You have to go to the AVS Forum. Someone wrote a scan program for your computer that allows you to access your video card and make fine adjustments to the overscan. Or you can buy a video card with HDMI out.
        thanks tom;i have the service manual for Sony kv36HS500 in a Cd i tried to upload it to this forum but it fail cause is to big file,
        i got it from the internet by just googling Sony Kv36HS500.
        what i needed was some good instructions within the service manual.
          I would try adjusting them first. Slowly and carefully while watching the image. CRT experts may be able to add more. I've never repaired one, and only primitively understand how they work.
            Isn't it easier to adjust the screen size from the PC's video driver?
            I would not do it with the TV, because the screen size will not be the same if you are using this input with other video sources.
              You maybe right besides on needs a special an hd monoscope,bellow are some instructions for the adjustments,
              2-9.2. 1080i HD MODE ADJUSTMENT
              1. Input a 1080i cross-hatch signal and an HD monoscope signal that
              contains overscan markers.
              2. Adjust the raster position per Section 2-8., only if this procedure was
              not performed for full mode.
              3. Adjust the geometry similar to Full DRC mode. Vertical size is 11.7
              ± 0.1 sq. and horizontal size is 15.6 ± 0.1 sq., if monoscope signal is
              available. Otherwise, set the Vertical size to 91.0 ± 0.6% scan and
              Horizontal size as 91.0 ± 0.6% scan.
              4. Use the following register to adjust the horizontal parameter:
                I gave you a simpler solution above.
