Vizio VM60P no picture has sound
  • bigcim
    • Mar 2013
    • united states of america
    Hello, I have a Vizio VM60P HDTV10A that i'm trying to fix. I was watching the TV and heard a loud pop/snap and the picture when out but the sound was still on. TV is responsive to the remote control(volume+-,channel change). I checked all the bus type fuses in OHMs and after showing up minimal reading go to 0 in 1-2 seconds.
    Thank you in advance for all help and god bless.
  • bigcim
    • Mar 2013
    Re: Vizio VM60P no picture has sound
    Can someone help me figure out what part need replacing thanks
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      From the sound of this so far, it sounds like something's broke.
      lol
      It could be caps, inverters, etc... it's hard to know at this point. Post pictures of your boards and the set's overall layout and it should give us come clues of where to go next. The good thing is that if it mad a popping sound, theres a good chance that a visual will catch the problem.
      • bigcim
        • Mar 2013
        Thanks for the reply, I will post pics ASAP. Form the research I done so far people say its a common problem fixed by replacing the Y sus board. I also read that you shouldn't replace the y with out the X sus as well. Sucks paying $2500 for a tv to have it break in 6 years. I searched for bulging caps but didnt find any but will see from the photos. Looking forward to the accomplishment of fixing it.
        • 1frankwright1
          • Oct 2011
          Wow not much help you have been getting on this...People seem to not want to help the newmbs much...we all start somewhere no?
          This tv is a plasma. A common issue with these sets are Ysus or Zsus boards.
          Maybe even the buffer boards went out also. Start by measuring standby voltages,check fuses,look for burned components and go from there.
          • ggil44
            Vizio M65-E0 No Picture, No Sound
            by ggil44
            Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
            09-03-2024, 08:30 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
            I ordered a supposedly β€˜new' Tcon board this time, and
            06-09-2024, 10:28 AM
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
