technika 42 lcd 910 power probs
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #41
    Re: technika 42 lcd 910 power probs
    i wonder do these sets also use the other ic as in the kit?
    • exmortis
      • Feb 2013
      • 27
      • u.k
      #42
      i dont think so
      • exmortis
        • Feb 2013
        • 27
        • u.k
        #43
        Originally posted by exmortis
        i dont think so
        these mosfets are probably my fault they have gone faulty , i accidently shorted one of the big caps when taking 24v reading on the invertor board , so i suppose the rapid discharge from the cap damaged them , hence me fault on the T.v changing ..oops
        • dejesus
          • 108
          • usa
          #44
          hi, tom66. Is Budm ok? I have not see him in the side lately.
            He was on yesterday...
            • matyka
              • Jan 2015
              • 179
              • Uk
              #46
              hi,I have exactly the same issue with this tv .Anybody found a solution ?
              • malogro
                Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                by malogro
                Hello all,
                I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                Intro:
                This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                04-14-2023, 04:44 PM
              • jose6326
                Samsung s32d850t powers off
                by jose6326
                Powers on as normal shows an image then powers off after 10 seconds
                I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                No blown caps
                I searched for this model but nothing comes up...
                11-29-2024, 11:21 PM
              • simwalsh
                Philips 47PFL4606 Powers on, works normal then powers off after a minute
                by simwalsh
                I am new to this forum and have searched for some answers with problems similar to mine.
                Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
                It sounds like a power supply issue?
                I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
                12-04-2023, 04:03 AM
              • SarcasticOP
                General question about MacBook power rails for repair.
                by SarcasticOP
                I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                • PPBUS_G3H (12.6V-12.8V)
                  • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                • PP3V42_G3H (3.42V)
                  • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                • PPVRTC_G3H (3.3V)
                  • This
                12-12-2024, 05:50 PM
              • CornholioGSM
                Dell P2720DC - Powers on only in test mode
                by CornholioGSM
                Hello
                I have Dell monitor P2720DC.
                Monitor powers on without problem, but shows only panel test - WRGB filled display - and i am unable to exit this mode...buttons does nothing.
                Is here any fix for this?
                Maybe reprogramm SPI with working img ?
                Monitor board is 715GA309-M02-000-0H5I...
                02-15-2025, 10:21 AM
