technika 42 lcd 910 power probs
+ More Options
Posts
  • vinceroger69
    • Mar 2012
    • 6714
    #41
    Re: technika 42 lcd 910 power probs
    i wonder do these sets also use the other ic as in the kit?
    • exmortis
      • Feb 2013
      • 27
      • u.k
      #42
      i dont think so
      • exmortis
        • Feb 2013
        • 27
        • u.k
        #43
        Originally posted by exmortis
        i dont think so
        these mosfets are probably my fault they have gone faulty , i accidently shorted one of the big caps when taking 24v reading on the invertor board , so i suppose the rapid discharge from the cap damaged them , hence me fault on the T.v changing ..oops
        • dejesus
          • 108
          • usa
          #44
          hi, tom66. Is Budm ok? I have not see him in the side lately.
            He was on yesterday...
            • matyka
              • Jan 2015
              • 179
              • Uk
              #46
              hi,I have exactly the same issue with this tv .Anybody found a solution ?
              • malogro
                Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                by malogro
                Hello all,
                I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                Intro:
                This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                04-14-2023, 04:44 PM
              • jose6326
                Samsung s32d850t powers off
                by jose6326
                Powers on as normal shows an image then powers off after 10 seconds
                I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                No blown caps
                I searched for this model but nothing comes up...
                11-29-2024, 11:21 PM
              • simwalsh
                Philips 47PFL4606 Powers on, works normal then powers off after a minute
                by simwalsh
                I am new to this forum and have searched for some answers with problems similar to mine.
                Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
                It sounds like a power supply issue?
                I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
                12-04-2023, 04:03 AM
              • Rekoo1997
                DELL Precision 3520 powers on automatically
                by Rekoo1997
                Laptop Model: DELL Precision 3520 Motherboard: CDP80 LA-E152P Rev 1.0 (A00)
                Issue: The laptop powers on automatically after being shut down.
                Actions Taken by Technician:
                BIOS reflashed
                Intel ME region cleared
                Result: Issue still persists
                Additional Observations:
                Power button reads 3.3V (normal)
                The problem occurs both when running on battery and when connected to AC adapter...
                08-07-2025, 08:48 AM
              • csmith
                Vizio D50u-D1 Powers up no picture
                by csmith
                I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                issue. Set will power up with remote but not power off....
                07-11-2025, 11:52 AM
