technika 42 lcd 910 power probs
  • exmortis
    • Feb 2013
    • 27
    • u.k
    Re: technika 42 lcd 910 power probs
    Originally posted by tom66
    You need to use low-esr capacitors. Farnell sell them as do RS. Capacitors from the average shop can cause lots of issues. Good capacitors to use are Panasonic FC, FM or FR.
    ok i have some others now good ones i try them instead now and keep ya posted many thanks
      Which ones do you have? Brand and series? Seriously, most capacitors are NOT suitable.
      • exmortis
        • Feb 2013
        • 27
        • u.k
        they where capcon ones same as removed , tv does the same , and i checked the 24v to the invertor and they do get a feed briefly then the tv clicks back off and the voltage drops off.
          Capxon are really poor capacitors.... I've replaced more of them than any other...
          • exmortis
            • Feb 2013
            • 27
            • u.k
            ok if i sort them what would be the next step to test ? iam stuck now on what to check.
            • exmortis
              • Feb 2013
              • 27
              • u.k
              #26
              what about Rubycon capacitors ?
                They are very good, but you can get a lot of fakes if you buy from shady shops, let us know the series (e.g. ZLH, YXF, MCZ) before replacing them as we need to know if they are low esr (not all Rubycon caps are.)
                • exmortis
                  • Feb 2013
                  • 27
                  • u.k
                  #28
                  they are MCZ are the series anygood
                  • exmortis
                    • Feb 2013
                    • 27
                    • u.k
                    #29
                    would increasing the microfarad on the replacements cause a issue i.e going from 470 to 1500 same voltage tho ?
                      Yes, almost certainly. And, MCZ are not suitable for TV PSU.
                      • exmortis
                        • Feb 2013
                        • 27
                        • u.k
                        #31
                        what next thing i can test once the caps are sorted ?
                          We can check the output rails and main board.
                          • exmortis
                            • Feb 2013
                            • 27
                            • u.k
                            #33
                            ok i been testing and checking components , i found a 4.7Mohm resister open circult which i replaced has resolved the buzzing issues from power supply, still remains in standby, i just been testing Mosfets on invertor and found n channel bottom 4 are at fault model fdd8447l 40v , iam right in saying they operate similar to diodes back to back and only allow current one way through ?
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #34
                              http://howtoblogpost.blogspot.co.uk/...st-mosfet.html
                                That is stolen verbatim from 4QD.
                                http://www.4qd.co.uk/serv/MOSFETfail.html
                                http://www.4qdtec.com/mostest.html
                                • exmortis
                                  • Feb 2013
                                  • 27
                                  • u.k
                                  #36
                                  yeah i think the 4 mosfets on the invertor next to the 2 caps are knackered i have to get some and change them and see what happens
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #37
                                    sure is stolen a good testing guide though tom can these be tested in circuit or have to lift the fets legs? i am never sure
                                      In circuit is usually OK, once a suspicious device is located, remove it from the circuit and test out of circuit.
                                      • exmortis
                                        • Feb 2013
                                        • 27
                                        • u.k
                                        #39
                                        anyone got 4x FDD8447l mosfets they can send us in the post, cant get any at the mo
                                          *cough*
                                          http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
                                          • nosaj
                                            Samsung QN82Q70RA powers on then powers off
                                            by nosaj
                                            I have a samsung QN82Q70RA powers on then powers off. Using some info on the interwebs. I disconnected main board from power supply and backlight shows blue and stays on indicating power supply is good. So next I unplugged one on the lvds cables that connects to screen( I think other side goes to tcon board?) i can get a blue screen and if I press the picture button on the remote i get rain sounds and birds chirping. A lot of videos suggest using kaptan tape to cover the clock signals, but I've been unsucessful there.
                                            So I thought I'd just quit messing around and come to the best site...
                                            11-07-2025, 04:58 PM
                                          • malogro
                                            Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                                            by malogro
                                            Hello all,
                                            I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                                            Intro:
                                            This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                                            Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                                            04-14-2023, 04:44 PM
                                          • jose6326
                                            Samsung s32d850t powers off
                                            by jose6326
                                            Powers on as normal shows an image then powers off after 10 seconds
                                            I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                                            No blown caps
                                            I searched for this model but nothing comes up...
                                            11-29-2024, 11:21 PM
                                          • SteveCHS
                                            Definitive BP7006 Plate Amp – Powers On, No Sub Output (Need Help Diagnosing)
                                            by SteveCHS
                                            Hi all — I’m trying to diagnose the plate amplifier from a Definitive Technology BP7006 tower.
                                            Symptoms:
                                            - The amp powers on (red light illuminated)
                                            - No subwoofer output
                                            - Main towers still play normally through my receiver
                                            - No audible hum or noise from the sub section
                                            What I’ve done so far:
                                            - Verified fuse continuity
                                            - Visual inspection: no burned parts
                                            - Confirmed speaker driver reads ~5Ω DCR
                                            - Board ID: LT-C126 (stamped on the PCB)
                                            - Cap glue confirmed factory adhesive, not leakage
                                            - Using a UNI-T...
                                            11-05-2025, 09:06 AM
                                          • riki_22
                                            ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
                                            by riki_22
                                            I’m working on an ASUS B5402CEA notebook.
                                            B5402CEA_MB_R2.2
                                            HA4YT LA-L861P
                                            REV:1B
                                            The board powers on, fan spins for a few seconds, then it shuts down by itself.
                                            I suspect the BIOS might be corrupted.
                                            Could someone please check and clean (repair) the attached BIOS dump?
                                            I’ve also attached a few photos of the motherboard for reference.
                                            Thanks in advance for your help!
                                            11-03-2025, 04:38 AM
