Tiny 42" plasma Tv (PS-42D8)
  • patant
    • May 2012
    • 5
    • Scotland
    I'm trying to repair a "Tiny" PS-42D8 plasma tv.
    The tv is stuck in standby and clicks once when power is switched on.
    I removed the back cover.No obvious failed caps or fuses.
    When powered on two green lights on the main board light up then one switches off and a red light comes on leaving one green and one red light on.
    The power board is a Samsung part No. : IP-423-SSA LJ44-00061A
    Was working fine until it decided to go into coma mode...
    Any ideas guys?
    Regards
    Patrick
  • martyparish
    • Dec 2012
    • 313
    Re: Tiny 42" plasma Tv (PS-42D8)
    Hi Patrick,
    It could be a number of things causing it to shut down prematurely. Things that come to mind are bad buffer ICs, fault on the power board.
    Please add clear pictures of the whole chassis and closeups of PSU and other boards.
    With the 42" plasma that I am working on now, I was able to unplug the Y Sustain power connection and then the TV would stay powered up. (with everything plugged in, got about same results you have).
    • Matt_Music
      • Sep 2014
      Hi martyparish,
      I currently have a 42" Plasma SD Tiny TV. Same power board and same issue.
      If you could help that would be greatly appreciated. Please ask what ever it is you need.
      TV Model: HC PLASMA TV-TY / PS - 42D8
      Board layout: S42SD - YD05
      Main Power Board: PS 423-SD V3.1 REV.01
      I can attach pictures if need be.
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Cooperr
        Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
        by Cooperr
        I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
        The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
        10-21-2025, 01:11 PM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        I happened several times, in the search for help from the web, to consult this very interesting forum.
        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
        Having said that I come to the gist of my post on the forum as the title suggests.
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
