This one is pretty beat up from the out side, the setup menu looks OK, but the video is full of noise. This seems to be common problem when this TV came out, the fix was to replace the main board. So far it is no affected by hot or cold. I will be doing more checking.
Samsung LNS4695DX bad main board
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None -
Re: Samsung LNS4695DX bad main board
This is a very common issue with Samsung DLPs, and I believe the main board is the same or very similar for these LCD TVs. One of those Samsung RAM chips has failed. You can remove and replace them.Last edited by tom66; 02-19-2013, 04:30 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
i have a recently given one of these to fix. Model # LN-S4695D to TOM66 you feel confident that the ram chips is the problem?Comment
Not certain, not done it myself....Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
My symptoms are pretty much just as pictured above.
one notable thing is ant menu driven on screen stuff looks fine.
it just goes wacky with hdmi input, all 4the same. and off air reception is same regardless of resolution it pics up.Comment
This one uses a mix of standard SDRAM and BGA type DDR(1/2).Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I parted it out.Never stop learning
I used the spare parts to fix other TVs, I have way many TVs to fix up, when parts of one TV can be used to fix other 3 or 4 then it makes no sense to fix one. Did you try the new chips?Last edited by budm; 05-05-2014, 04:06 PM.Never stop learning
by Asraf AtbHi everyone,
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by Lee M.When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... -
by JDCONN 100012588
Issue: No Power, Then Rebooting After Main Board Change
Short answer: replace main board and power board
Technical answer: replace main board and Q306 & Q307 on power board.
Long answer:
TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge.... - Loading...
