ok need help with samsung 46 inch lcd tv colour issue
  • nelfig
    • 23
    • canada
    so i picked up this used samsung ln-t4661f that didnt power up low and behold 3 bad caps i changed them and tv turns on works great except i find it a bit greenish in colour even using all the features on the menu it still weird in colour now could it be the ribbon cable not connecteing properly or is it the t-con board now can i reflow a t-con board or is it best to buy a new one
    Re: ok need help with samsung 46 inch lcd tv colour issue
    Can we see a picture of the effect?
    It is possible to adjust precise colour balance factors in the service menu, as well as performing a complete reset.
    • nelfig
      • 23
      • canada
      here's the video i posted on youtube so tom how do i do a complete reset is there a button for it somewhere??
      http://www.youtube.com/watch?v=xp1uapJuEiY
      • Mr Bill
        • Nov 2011
        • 648
        Does twisting the panel correct the color or change the apperance? Repaired a 46" sanyo 2 days ago that had a similar looking effect and the TAB ribbon on the far right side was loose.
        • nelfig
          • 23
          • canada
          also i changed 3 capacitors on them the original ones were valued at 2 was 1000uf 10v and the other one was 1000uf 25v i changed the two with 1000uf 16v and the other one i did 1000uf 35v should they all have been rated at 1000uf 35v ???
          • nelfig
            • 23
            • canada
            i tried the twisting thing and it didnt work
            • nelfig
              • 23
              • canada
              ok i just learnt the code reset thing (mute 182 power) it seems to have help but with the cartoon i had playing its like a trailing effect so what now ???
                The panel is defective due to bad tab bonds, most likely.
                • tibimakai
                  • Jan 2012
                  • 3680
                  But is shouldn't be darker also, on one side of the panel?
                    Not always, panel defects can be regional or global.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      https://www.youtube.com/watch?v=purk_SyiT44 found from toms posts
                      good video shows how to fix tab bond issues
                      • nelfig
                        • 23
                        • canada
                        so what you guys think t-con board or inverter boards??
                        • awyatt2
                          • Feb 2012
                          • 407
                          • america
                          you most likely have bad tab bonds, in which case neither will help.inverter boards won't cause this.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            Inverter for sure is not,because when you have it on the static screen it stays on.
                            I had a Toshiba 42" that initially it had a perfect screen and suddenly it would freeze and black out the whole screen. It's not the same symptom, but it's similar and for me, another T-con board fixed the problem.
                            You should remove the plastic bezel, remove the metal LCD case and touch all the tabs, to see if anything changes.
                            • nelfig
                              • 23
                              • canada
                              i checked the tabs and visually they seemed fine i guess ill take the chance and see if i can find a cheap used t-con board
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Did you move them around a bit?
                                • nelfig
                                  • 23
                                  • canada
                                  yep but no luck
                                  • MisterD
                                    • Oct 2012
                                    • 668
                                    Take a hair dryer and heat up the tab bond areas and see what happens then.
                                    • nelfig
                                      • 23
                                      • canada
                                      the tabs are all on clips there not the glue down types so im getting a feeling that the panel is not good no more
                                      • Kjell
                                        Samsung Series 9 - BIOS issue
                                        by Kjell
                                        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                        08-01-2025, 09:15 AM
                                      • Acnologia
                                        Lenovo Thinkpad T540P - Showing at 14" inch but NOT at 15.6" inch (Backlight issue) ?
                                        by Acnologia
                                        Hello to all members of badcaps.
                                        Another brainstorming that i have been messing with for months as a side project.
                                        Bought a T540p , from eBay as 'doesn't display' ,so i thought it was either backlight fuse, or screen issue etc.
                                        I got it in my hands, first thing, the machine works fine boots to windows , in external screen all diagnostic are good.
                                        Step 1.
                                        Change screen (FAT - LED ) 1366x768 to 2nd one, that i know 1000% that is working ,as it has been tested.
                                        Machine > Doesn't give display it's really dim.
                                        Step 2.
                                        Use the same...
                                        11-05-2025, 04:02 AM
                                      • Nairolf
                                        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                        by Nairolf
                                        I have a Samsung DM32D display.
                                        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                        Here’s what I have tried so far:
                                        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                        From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                        08-24-2025, 03:47 AM
                                      • vincentedel
                                        Samsung SyncMaster 740n Phase Control Issue
                                        by vincentedel
                                        I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                        I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                        04-22-2025, 12:33 AM
                                      • Manucsl
                                        QE65Q800TATXXC Samsung TV Issue
                                        by Manucsl
                                        Hello.
                                        My TV is a QE65Q800TATXXC Samsung TV.
                                        Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                        Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                        Any ideas to check would be very appreciated 😊
                                        After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                        02-19-2025, 07:47 AM
