Hitachi 55VG825 Ballast testing
  • uberplasma
    • Oct 2011
    • 85
    Hi everyone
    I have an Hitachi 55VG825 55`rear projector that blew a bulb, it was the OEM bulb from 2005, so it was not that unexpected that it would go, got 3200 hours of it so not too shabby. I ordered a replacement bulb and installed it and within 30 seconds it blew, and since I had the rear cover off I noticed that the gas discharge tube was lighting up every few seconds. Ballast`s are somewhat out of my normal line of repairs and was wondering if there anyone knew how to troubleshoot the power without a scope or high voltage adapter for my meter.
    Tv is in great shape, from father in law so I know that there was no previous service performed and the Tv was well looked after , he got rid of it only because of the bulb blowing.
    Here are some pics, dust has all been blown out, very clean, no visible damage to any component or any odd smells from the boards.
    Any help or direction would be greatly appreciated.
    Cheers
    (couldn't edit first post so reposted)
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Hitachi 55VG825 Ballast testing
    I don't see how a ballast like this could blow the bulb, but I can see how the ballast might be giving a lower output voltage than what is needed. Your original bulb might still be good...
    Ever seen the streetlights go on and off at night? That is because (in this case!) the bulbs are going bad. They require a higher voltage than the ballast can supply when the lamp is hot, and so they flash on and off repeatedly.
    However, if the ballast is bad (not supplying enough voltage when lamp is hot) then it will do the same thing.
    Before replacing the ballast, I suggest you try cleaning off the lamp holder contacts very well.
    Muh-soggy-knee
    • selldoor
      Slow Learner
      • 7870
      I think the question is did the bulb blow or is it just not lit?
      Did you reset the lamp hours
      I also recall reading (years ago so may not remember correctly) some
      lamps are in a compartment with a door and if the door is not shut correctly
      a switch stops it lighting.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Good points, I agree, check those things too!
        Muh-soggy-knee
        • R_J
          • 9623
          If the gas discharge is lighting you have highvoltage from the ballast, but there is no load check connections to the lamp, if the lamp is broken or open in any way the discharge tube will activate to protect the ballast.
          • uberplasma
            • Oct 2011
            • 85
            Hi
            thanks for all the responses:
            Yes the original bulb blew the filament, shattered inside the bulb. The replacement bulb went in fine, good connection and powered up fine and then did the same thing: filament shattered in the bulb within 30 seconds, then i noticed the gas discharge tube glowing, i was looking to see if the foperating, thinking over heating, but they were working. The door switch was rigged closed as I had the back cover off for cleaning(and I am curious)
            I will try to find out how to reset the hours
            thx
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Originally posted by uberplasma
              Hi
              thx
              I think you will need a new ballast, this one is simply putting waaay too much power through the filament!
              Muh-soggy-knee
              • R_J
                • 9623
                These Lamps don't use a filament. its possible the replacement lamp was bad ie cracked during shipping or instalation
                • uberplasma
                  • Oct 2011
                  • 85
                  Hi
                  I was thinking too much power too. here are some pics of the bulb, this is the OEM and the replacement looked the same.
                  I quess I will have to start checking voltage regulators in the ballast to see if one is letting too much voltage through
                  the replacement came from the distributor with the void if removed sticker already damaged so I am kind of stuck if it is damaged from transport.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Reading up online, it seems that if the ballast isn't giving the lamp enough power, then it could blow the lamp too!
                    In this case, either:
                    1. The HV transformer has some internal arc-over, and hence some shorted windings (lower output voltage).
                    2. One or more of the film capacitors has decreased in capacitance, causing a lower power output.
                    3. The filter capacitor is bad, although highly unlikely b/c this one is a quality Japanese capacitor made by Nichicon, which looks to have a flat top (not bulged out).
                    4. One of the switching transistors has degraded.
                    5. The little electrolytic capacitor has gone high ESR, and is causing instability in the ballast circuit. (Very common for them to go high ESR, even good brand ones do that in hot places!)
                    6. May be more things to look at, can't think of them right now...
                    Muh-soggy-knee
                    • uberplasma
                      • Oct 2011
                      • 85
                      Hi
                      swapped out the ballast and TV runs perfectly. Hard to say if it was the ballast all along or light damaged in shipping, but have lots of ballast hanging around,so it works thanks for all the input!!
                      Cheers
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Hi
                        Cheers
                        Good job!
                        Muh-soggy-knee
                        • repair-it
                          TOSHIBA DLP 52HM95 How to reset timer module on bulb
                          by repair-it
                          I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                          Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                          10-11-2023, 07:18 PM
                        • ezenia
                          LUMIMAN Smart Bulb IC ID?
                          by ezenia
                          I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                          In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                          04-28-2025, 05:56 PM
                        • Jaime Morillo
                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                          by Jaime Morillo
                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                          The TV was stuck on the logo and I couldn't access the update menu.
                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                          The image result was good, but the image is inverted.
                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                          08-18-2025, 11:38 AM
                        • wolf1976
                          hitachi 50hk5600 problem with display
                          by wolf1976
                          hi
                          i have the above tv and the display starts distorts the display at only in applications like you tube
                          after and on the didital channels
                          now without connect the antenna only the image of itsselfs tv i have the image i have in attach
                          i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
                          can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
                          09-13-2025, 02:26 PM
                        • JimBanville
                          Replacing incandescent bulb on Pioneer LD player with led. Need help :)
                          by JimBanville
                          I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
                          Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
                          01-24-2023, 07:49 AM
