Philips Plasma
    Philips Plasma
    I have a Philips plasma tv Model # 50pf7321d5 that I just replaced two bad caps. When I plugged it in and turned it on the green light at the bottom came on then flashes red four times. I noticed the power board has two green lights but the one on the right doesn't come on. I'm not sure what I should look at next any help would be appreciated.
    Re: Philips Plasma
    Moved from FAQ.
    sigpic
    (Insert witty quote here)
      Re: Philips Plasma
      What is the chassis code of your TV? This will be on the same sticker as the model number. It will either be in a box marked "S", or indicated next to "CHASSIS".
        Re: Philips Plasma
        Also, that model number must not be correct, because a Google search on it brings up only ONE result, this thread
          Re: Philips Plasma
          sorry should say d37 not d5. I found a tiny burn in the power board like the size of a pencil tip. I'm told it's not repairable so i'm pricing out powerboards now.
            Re: Philips Plasma
            Double post - forget this one
