Hello Badcaps members. I'm working on this set with the notorious bad buffers. I was hoping to find the bad caps on the PSU but it appears that it's the Y Main/Y buffer issue instead.
I have confirmed this by disconnecting the Y power feed and then the set will stay powered up. With everything hooked up, the set does the 7 blink and shuts down.
So, the question: How in the heck do I get the Y Main and buffers out?
I have removed the vertical main structural rail and all screws on the main and both buffers. It still seems to be attached somewhere near the connections between the buffers and the main.
I am wanting to remove these in order to test the y main and each buffer to get a better idea of what has happened. I am aware that they should all be replaced together and I doubt that will happen due to the extreme cost
It would still be nice to at least check them, if only for my experience
Thanks!!!
Thanks!!!
