Bush IDLCD26TV16HD - Dim flickering backlight - Fixed
    Just fixed this one with a friend. Two 10uF 400~450V caps on PSU replaced. Had been done before -- only one replaced with a 400V Samwha RD. This cap smoked upon application of power. It is important to make both caps 450V or higher! Replaced both with Rubycon BXC (10uF 450V) and it works great.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Bush IDLCD26TV16HD - Dim flickering backlight - Fixed
    nice easy fix tom did this one have the built in dvd like the one i was trying to fix? send me some links of some easy fix ones to buy haha.
      No DVD built in.
      Look on Gumtree etc. I'm not going to find them for you!
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        i was only joking hahahah. yes i do daily dont worry i dont mind traveling either as long as there the right price do you find 26in lcd sell ok i usually only go 32in and higher.
          I can sell 26" easily to students about £80~£90 each. Only paid £25 for it plus £1.50 in caps.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            i forgot you had the students to sell to yes ideal size for the dorms etc.good mark up on that one and you work on the same as me £1.00 a inch when buying unless i have to travel more.
              I will pay more for really good TVs like the 46" Panasonic I have now.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                I am still looking for one dont worry but will probs need your help repairing it please.I am trying to sort some pc stuff out today to build a media pc up so doing that at the minute as should have all the parts in the shed to do it although i might need a new graphics card with hdmi on.
                  I will offer what help I can.
                  I am on the look out for another to fit in the basement . I would also settle for a NEC, Pioneer or LG plasma.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    what size screen you looking for tom what distance would you be willing to travel? between me job searching etc i also visit a lot of free add sites and do see some some sets on offer really cheap but i don't always have the money myself so i can send you the links/adds if you want as you may not have time to source them with you university course work.
                      I'm after a 50~61" plasma for the home cinema. I know NEC made a very nice 61" 720p one that few are brave enough to touch as it has a lot of issues with the PSU. Won't stop me though. 55" Hitachis are nice, and almost full HD (1280x1080 ALIS.) Not gonna touch any LG using IPMs but their newer plasmas are OK. Not fantastic, but "OK".
                      I have quite a bit of free time. I will be challenged around exam period, but that is it.
                      • gilly1984
                        • Jun 2012
                        • 751
                        Was this the ipos 150?
                        May help with peoples search to include it .
                        Do NOT touch heatsinks when testing for voltages as they may be LIVE!
                          Yes. IPOS 150. IPOS = "Integrated Piece of S**t"?
                          • reessi
                            ACER BM320 Monitor - Horizonal Flickering Lines After a While
                            by reessi
                            The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                            They are black on the right and gradually fade to nothing on the far left.
                            They start either after 5 mins or up to 2 hours after so annoying for testing.
                            They flicker continuously very fast! With a slight pause milli-second every second.
                            Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                            I tested each half by removing the first the left flex from...
                            06-03-2025, 09:58 AM
                          • DrvLikHell
                            Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
                            by DrvLikHell
                            Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
                            The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
                            07-05-2024, 02:54 AM
                          • Jaysean
                            Acer VN7-591G-70RT Display Flickering
                            by Jaysean
                            Hello Badcaps coummunity hope you all are having a bless day,
                            Hope I didn't post it wrong kinda new at forum site rules and tradition
                            So I'm dealing with screen flickering problem on my laptop.
                            I'm not quite sure if it's the display cable or the screen itself that's causing the issue,
                            so I'm turning to you all wonderful expert on Badcaps for some guidance. Your help is much appreciated!
                            [Screen Flickering](https://i.imgur.com/xK9vHqc.mp4)
                            [HDMI port to external display seem to work be working](https://i.imgur.com/snSC24e...
                            10-27-2023, 10:22 AM
                          • FlailingEngineer
                            Help with Bush Tv (Vestel 17mb95m Mainboard)
                            by FlailingEngineer
                            Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                            Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                            05-31-2023, 06:52 AM
                          • howardc64
                            Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                            by howardc64
                            TV was fixed just after removing Samsung's rear snap cover.
                            This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                            Maybe PSU->backlight connector didn't have a good contact?...
                            07-23-2025, 12:34 AM
