DP42848 Sanyo No sound, blown HDMI
  • belamex
    • 12
    Not sure what the problem is but I have no sound and the HDMI does not work. It there are fix?
  • johnboy1313
    • Nov 2012
    • 1959
    Re: DP42848 Sanyo No sound, blown HDMI
    Do you have proper voltages at the PSU? If so, I would suspect the main board. I believe it has both the audio amplifier and the HDMI input for that set.
    • awyatt2
      • Feb 2012
      • 407
      • america
      yep, you are 100% on johnboy. they are both on the mainboard and these mains seem to give a great many problems. i am waiting on a main for one that has been three weeks. under ext. warranty from walmart.
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • japlytic
        Not all TVs can handle surround sound on a HDMI input
        by japlytic
        With a home theatre PC connected to a TV via HDMI, Windows reveals that the TV only supports stereo sound even though the TV has a HDMI ARC connection to an AV receiver which is powered on; I also had an issue that the AV receiver does not always retain the input setting for routing the HTPC video through to the TV in standby.
        So I connected a second HDMI cable to the HTPC and set it to duplicate the video outputs, but I had random audio dropouts when playing content with surround sound being passed to the AV receiver (dropouts did not occur when I replayed the content where it dropped...
        08-31-2022, 10:09 PM
      • hugocarmo
        Sanyo VHR-D4710G VCR no sound.
        by hugocarmo
        Hi again guys.
        Today I have a problem with this Sanyo VCR.
        I bought it online, It worked sometimes.
        I recap the Power supply and it started working fine.
        Image is perfect and all digital effects too.
        All of a sudden it stopped outputting sound. I checked for dried solders an all boards and soldered when needed, no fix.
        I have no sound on playback, on tuner, or aux in.
        On symptom I noticed is when it was working fine, the HI-FI led was on when I power up the VCR, now is OFF, A-B leds are on but when I put a tape they go off.
        On one of the sound processing...
        01-23-2024, 12:58 PM
      • CraigR
        lg 46LD550 HDMI no sound
        by CraigR
        I got in a LG with no signal on HDMI ports so I replaced the HDMI IC and now I have picture but no sound on just the HDMI the other inputs are working fine for sound. Any ideas? Would the amplifier ic have anything to do with just HDMI?...
        10-05-2022, 01:13 PM
      • aidanmo
        Philips 43PUS7506/12 - Loud blown out sound
        by aidanmo
        I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
        I thought maybe the speakers got damaged, so I replaced them - no dice.
        • Using the internal speakers, it always happens.
        • Using the headphone jack, it never happens.
        • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
        02-28-2025, 03:13 PM
