Panasonic TC-P55ST30 TV is not turning on.
  • PBSB
    • Apr 2015
    • 3
    Re: Panasonic TC-P55ST30 TV is not turning on.
    Got the SC board and the SU board fixed. 14 blinks is gone and I get picture. However, it has lines in it. Is it because of improper connections (such as for the ribbon cables) or is still some issue with the boards? If connections, which ones are the possible culprits?
    • flocko
      • Nov 2012
      • 1121
      #42
      If the lines go from left to right across the screen, make a note of were they are and reseat the ribbon that is feeding that, but make sure to turn the set off from the wall socket before adjusting(do not try reseating when the set is on as you will damage the PDP) Hope this is of help Flocko
      • PBSB
        • Apr 2015
        • 3
        Everything working well, finally. First time I sent out the SC board for repair, it wasn't done properly and I still had the short on it. Then I discovered that the SU board also had a short, so got that repaired. Not having a supply of new boards is a huge hassle - Panasonic should be ashamed of how they've dealt with this issue. Anyway, after reseating the ribbon cables, the lines went away and the picture is normal.
        Thanks to everyone, especially TW2005 (and flocko above), whose contributions in this thread made me believe I could handle this one, and whose advice actually enabled me to do that.
        • ugamazing
          by ugamazing
          12-17-2024, 07:05 PM
        • Erik Masters
          Panasonic plasma A boards/Kuro media box repair.
          by Erik Masters
          Hi all.
          I have 2 Panasonic plasma A boards for ST50 50"/65" and Kuro KRP 500A media box which needs repair.
          I'm not good enough at component repair so I need some help.
          A boards and especially Kuro media box is still very valuable and I can't throw it away like some average Joe,lol
          I'm from Europe/Slovakia and I'm searching for someone who is willing to repair these things or some tips at least.
          Both A boards have HDMI issue either no signal or flickering.
          And media box possibly with voltage regulator issue which is common...
          11-17-2022, 04:47 AM
        • BigPete
          Panasonic Heatpump Dryer Repair
          by BigPete
          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
          Unfortunately the whole machine has to come apart to fix it.
          I have...
          11-01-2025, 06:40 PM
        • Amraks
          Panasonic SA-MAX770 (not turning on)
          by Amraks
          Hey all its been awhile since I have needed to post here.
          Panasonic - SA-MAX770: Symptoms not turning on
          Power Supply
          C1403 has 330v
          IC1402 Looks perfectly fine no blown out holes.
          C1601 has 3.3v
          CN1851 Has its 3.3v but no 15v all I am getting is on the 14v rail is 0.400v
          Not sure where I should be looking next for this any help would be appreciated...
          10-04-2022, 12:12 AM
        • midnightg35x
          Panasonic TC-P65S2 SU or SD Boards Bad?
          by midnightg35x
          I have a TC-P65S2 that blew an SC board (I had a previous post about some cross references). When I put the repaired SC board in, it worked with the SD and SU boards isolated and SC50 jumped. I reinstalled the SD and SU boards. I did forget to remove the SC50 jumper, but from what I understand about how that jumper works, that should not cause SC board destruction with properly working SC/SD/SU boards. When I turned the TV back on, the SC board blew again. Based on the fact the SC board was working without the SU and SD boards, it at least makes sense that one or both of them is bad.
          04-22-2019, 05:29 PM
