Panasonic TC-P55ST30 TV is not turning on.
  • PBSB
    • Apr 2015
    Re: Panasonic TC-P55ST30 TV is not turning on.
    Got the SC board and the SU board fixed. 14 blinks is gone and I get picture. However, it has lines in it. Is it because of improper connections (such as for the ribbon cables) or is still some issue with the boards? If connections, which ones are the possible culprits?
    • flocko
      • Nov 2012
      • 1121
      • uk
      #42
      If the lines go from left to right across the screen, make a note of were they are and reseat the ribbon that is feeding that, but make sure to turn the set off from the wall socket before adjusting(do not try reseating when the set is on as you will damage the PDP) Hope this is of help Flocko
      • PBSB
        • Apr 2015
        Everything working well, finally. First time I sent out the SC board for repair, it wasn't done properly and I still had the short on it. Then I discovered that the SU board also had a short, so got that repaired. Not having a supply of new boards is a huge hassle - Panasonic should be ashamed of how they've dealt with this issue. Anyway, after reseating the ribbon cables, the lines went away and the picture is normal.
        Thanks to everyone, especially TW2005 (and flocko above), whose contributions in this thread made me believe I could handle this one, and whose advice actually enabled me to do that.
        • ugamazing
          Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
          by ugamazing
          I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
          We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
          12-17-2024, 07:05 PM
        • Erik Masters
          Panasonic plasma A boards/Kuro media box repair.
          by Erik Masters
          Hi all.
          I have 2 Panasonic plasma A boards for ST50 50"/65" and Kuro KRP 500A media box which needs repair.
          I'm not good enough at component repair so I need some help.
          A boards and especially Kuro media box is still very valuable and I can't throw it away like some average Joe,lol
          I'm from Europe/Slovakia and I'm searching for someone who is willing to repair these things or some tips at least.
          Both A boards have HDMI issue either no signal or flickering.
          And media box possibly with voltage regulator issue which is common...
          11-17-2022, 04:47 AM
        • Amraks
          Panasonic SA-MAX770 (not turning on)
          by Amraks
          Hey all its been awhile since I have needed to post here.
          Panasonic - SA-MAX770: Symptoms not turning on
          Power Supply
          C1403 has 330v
          IC1402 Looks perfectly fine no blown out holes.
          C1601 has 3.3v
          CN1851 Has its 3.3v but no 15v all I am getting is on the 14v rail is 0.400v
          Not sure where I should be looking next for this any help would be appreciated...
          10-04-2022, 12:12 AM
        • midnightg35x
          Panasonic TC-P65S2 SU or SD Boards Bad?
          by midnightg35x
          I have a TC-P65S2 that blew an SC board (I had a previous post about some cross references). When I put the repaired SC board in, it worked with the SD and SU boards isolated and SC50 jumped. I reinstalled the SD and SU boards. I did forget to remove the SC50 jumper, but from what I understand about how that jumper works, that should not cause SC board destruction with properly working SC/SD/SU boards. When I turned the TV back on, the SC board blew again. Based on the fact the SC board was working without the SU and SD boards, it at least makes sense that one or both of them is bad.
          04-22-2019, 05:29 PM
        • Andre Gilbert
          by Andre Gilbert
          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
          11-20-2024, 08:52 PM
