Re: TV Repair Reference Library
There's a big ol' stash of Panasonic service manuals for everything from TVs to air conditioning and meatgrinders here, together with other service-related material:
http://www.sm.azhand.co/
The entire site structure is available freely with folder-browsing enabled.
There is an FTP-server as well but it doesn't allow anonymous login, so all downloads have to be done by HTTP.
This is a sticky topic.
Teardown Pictures:
http://www.tgohome.com/Teardown%20Pi...0Plasma%20TVs/Leave a comment:
it's related to gamma ic in tcon board when you have solarized pictureLeave a comment:
https://www.badcaps.net/forum/showth...service&page=4
May be in here.Leave a comment:
Hi I tripped my switch in my Pioneer PDP-435PE tv box and don't know how to fix it I rang a shop up and they said it only take 10mins to fix but it a hundred miles away do anyone know how to sort out the problem thank you.Leave a comment:
Sem2107
Just read this in one of the threads.
Inverter board SSI_400_14A01
Jump pin 7 to ground to override the lamp protection.
More information at https://translate.google.com/transla...ml&prev=searchLast edited by dick_barton; 05-29-2018, 11:05 AM.Leave a comment:
Спасибо, брат, за замечательную темуLeave a comment:
Is there a Logic Board LED Fault Code reference?
Have an LG with no video only audio....the logic board green LED light keeps lighting up
1 Long and 2 short pause.....
Wonder if this is a fault code....Leave a comment:
Vizio TV suck in boot up screen when turned on.
Need a little help here... i've been looking for a similar thread but can't find anything.....
I have a Vizio , model number E3DB420VX, and the mother board number is 3642-1462-0150(7b).
After looking and researching on the internet for the last two days it seems that all arrows point to the EEPROM CHIP.. however i can't find the location of the chip and nowhere on the internet is it listed.... question is, IS it on this motherboard or is it integrated like the emachine computers of old.... yes i'm that old. If someone can point out what the location number might be that would be awesome. The only station numbers i have seen that remotely look like eeproms are U2,6,8,10. All others look like something else. I've contacted shopjimmy and anybody else listed and they told me to come here. So here i am. I appreciate all suggestions...
DannyLeave a comment:
OZ9938 Protection Overide
From one of the repair threads.
I was looking at the OZ9938 datasheet and i thought to myself, why dont i try to disable protection just to see if the ccfl's will keep on !
So i shorted pin 3 between the resistor and the capacitor to pin 16 and it worked.
The ccfl's will not go off.Leave a comment:
yes, as above said I'd like to share something. A useful tutorial to solve TV issue.
1. Corrupted MP4 video
For the already damaged MP4 video, you can repair corrupted MP4 first and then try to play.
2. Encrypted MP4 video
If the MP4 video is encrypted or requires authorization, it can not be played if there is no license or specified program.
3. MP4 video is Stored on USB
If the USB does not support high-speed transmission, it will probably not be able to play smoothly or even fail.
4. Higher Bit Rate or Frame Rate
As the Samsung TV models are different, it will lead to playback failure if the bit rate or frame rate is higher than the supported standard value.
5. Incompatible Codec
The most common Samsung TV MP4 playback problem is because of incompatible codecs. (source from http://www.videoconverterfactory.com/tips/samsung-tv-mp4.html.)Leave a comment:
Needed dump?
COMPATIBLE PRE-PROGRAMMED EEPROM
Digitrex CTF3271
U17 Flash W25Q16
or:
EVOTEL ELCD40USBFHD
T.SP9100.1D 9252
U17 Flash W25Q16
or:
Model No/sn032L153
Chassis MB T.SP9100.1D 9252
Main board MB T.SP9100.1D 9252
LVDS/TCON 320ap0302lv0.1
Panel -samsung lta320ap02
Tuner analog/digital -cdt-sft33840
U17 Flash W25Q16Last edited by cipy1; 08-30-2017, 09:31 AM.Leave a comment:
Hello, I want to know how fix backlight failure in a westinghouse 32' lcd tv DW32H1G1Leave a comment:
I have a samsung UN60H6203AFXZA with issues to be completely honest I am a novice at best.I have replaced all three boards and the TV will not turn on unless I do not have the LED back lights connected power supply board. The TV does turn on but only when the LED lights are not connected to the power supply board I did a flashlight test that lets me see an image however I don't know how to tell if I need new LED lights or if my power supply board that I ordered was bad. I Am brand new to this site and do not know how to navigate it yet do not wish to break any kind of protocol just do not know where I should start seeking help at?Leave a comment:
another source for manuals:
http://www.electronica-pt.com/index....,select/id,13/
or
http://www.eserviceinfo.com/Leave a comment:
This is wrong thread to post your repair questions!Leave a comment:
by blues_spiritHello from France,
mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
Do you think this is feasible for me? I... -
by speaktorobSo a while back, to deal with the fan noise of the old blower style shrouds on the reference cards, I chucked it and installed the monster that is a Raijintek MORPHEUS 8069, with a couple Noctuas on it. Did the job but quite unwieldy tbh.
Anyone know which boards would have a compatible shroud for it? I know the EVGA used the reference board but wondering if any other manufacturers did. I want to put something sensible back on it, but I'm having a hard time getting hold of even a faulty reference board for a reasonable price.-
by gcrezzThe issue with this video card is the HDMI port. Specifically on pin 19 (Diode checks on all other pins are normal). When i do a diode check on it from the pin on the board itself, I have nothing. There is also no short on the pin. Resistance reads about 200k. Normally on any HDMI pin 19 I would expect some voltage drop anywhere from .5v to 1.2v but here, I have nothing. The card is operational and can be used via the displayPort ports, but not through the HDMI. Attached you will find the pdf schematics for the card on page 22. I have verified that all of the resistors on this line before the...07-25-2024, 09:49 AM
Hello all,
As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere... -
by RhorkHello,
I would like to know the reference of a QFN-20 because the reference marked on the chip does not give anything...
PC Reference : HP Pavilion - 15-cs0006nf
Motherboard : DA0G7BMB6D0 rev D
Reference marked on the chip: AWVAIL
Type : QFN-20
I didn't find a boardview or repair schematics
Thanks in advance... - Loading...
