vizio vp50
Re: vizio vp50
is it possible that it's bad and acting as a pass thru thus creating a 16 volt reading on the power board thus meaning it's having a 16 volt input to the tl431? on the power board????????? kinda what it doing on this breadboard setup....with the 7.64 volt input...and it outputting same voltage..
i do have tl431 on a different power board i can desolder and retest should i commence?Last edited by heavymachines; 01-20-2013, 01:50 PM.Comment
Re: vizio vp50
I suspect the part is faulty; this is causing your low voltage readings.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Re: vizio vp50
Please try with the other TL431 so we can check the testing method is right.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: vizio vp50
Ah I realise I may be in error here. Just realised...
Try moving the ref connection from 1-2 to 1-3.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: vizio vp50
i think so because i just tested two more both from different junk power supplies and same result...Comment
Re: vizio vp50
You want to do positive probe to resistor, negative probe to ground/battery negative.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: vizio vp50
I don't understand the 4.97V. Do you have other resistor values?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: vizio vp50
okay found resister brown-black-brown-gold-yellow measures 100ohms on dmm and voltage results are 6.74v input and 4.21v measurement at neg probe pin 1 and positive at resistor endComment
Re: vizio vp50
Either it's wired up wrong or the device isn't working, can you compare to the other devices, also what is the part # on it?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: vizio vp50
I'm suspicious of your meter battery. Can you make sure it's OK?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: vizio vp50
okay got 2 new batteries measure 9.3 volts each now that same voltage is input for bread board now reads 6.65 voltsComment
by u666saLaptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
Platform: ipa32 la-m024p rev 1b
Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
I found a short on the other side:
...10-04-2025, 05:03 PM -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by supermattchHi everyone.
I am diagnosing my personal laptop, because it wont power on and no leds light up.
At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.09-23-2025, 12:13 PM -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... -
by MisterAILHi everyone,
Brought a non functionnal PS5. Apparently only a bad PSU...
No beep, nothing.
After some tests i found this :
- PSU is fine (12 volts stable)
- 12 volts line is shorted
- DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
- By the way, nothing change. No signal, no power, no beep.
Mesuring all rails with my workbench psu (12 volts input)
- 0.00 amp drawing
- 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...5 Photos - Loading...
