E-Motion X23/69E super easy fix :)
  • gilly1984
    • 751
    So, just picked this tv up, lady said it had no display, but sound was fine.
    Get it home and it was obvious someone had tried opening it but not succeded, snapped screw mounts so some screws no longer screw in. I went ahead and opened it, its one where the front bezel comes off then you unscrew the screen mounts and lift the lcd panel up to reveal the boards.
    Anyway, here is some pics, sorry for quality, no idea where cam charger is?
    This is exactly as i found it, can you see the problem??
    Its full hd 1080p, with usb, freeview and dvd. Only 23" but who cares, it only cost me £20
    Oh, and how cute is that power supply.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
    Re: E-Motion X23/69E suoer easy fix
    E-Motion is Sainsbury's Supermarkets own brand.
    Looks a lot like the Grundig, Bush and Technika ones I have fixed before, I think they are made by Haier.
    • gilly1984
      • 751
      But can you see the easy fix?
      Samsung display.
        Of course. The LVDS cable isn't connected to the main board. Or perhaps the main board isn't connected to the LVDS cable? Hmm...
        • gilly1984
          • 751
          Yep, how the hell could that of happened? Dropped?
          Do the makes you said also have samsung panels in them?
            The Goodmans and Bush used a Chi-Mei.
            The Technika used a Samsung.
            • gilly1984
              • 751
              If this was yours, what would you sell it for?
              Gonna have to let the missus find more tvs with easy fixes like this. When i find them it takes me ages to fix it.
                I sold a 24" Bush for £75 and a 22" Goodmans for £35 (had a line stuck on the screen though.)
                • gilly1984
                  • 751
                  Was they full hd with same features? usb and what not. Can pause, record and rewind freeview too.
                    Aside from the Freeview pause/rewind/record it was full HD, CCFL-backlit, built in Freeview, single HDMI, and had USB support (playback media only.)
                    • gilly1984
                      • 751
                      Been offered £60 so far. Thanks.
                      • MORETTIGIAN
                        Capacitor detached from PCB – RTX 2070 Super Founders Edition
                        by MORETTIGIAN
                        Title:
                        Description:
                        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                        I did not notice it detaching, so I am unsure of its original location on the PCB.
                        Procedure performed:
                        - Removed backplate
                        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                        - Reapplied thermal compound
                        - Reassembled card
                        Observed behavior after reassembly:
                        - GPU powers on and operates normally under...
                        09-18-2025, 12:14 PM
                      • Destroyer-Br
                        [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                        by Destroyer-Br
                        I'm working on an Acer Nitro 5 unit with the following specs:
                        • Motherboard: LA-J871P Rev: 1B
                        • Model: Acer AN515-55-59MT
                        • S/N: NHQ7JAL00403906A973400
                        • SNID: 03902728734
                        Initial Issue
                        The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                        After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                        04-17-2025, 08:18 PM
                      • AJ847.63e
                        Playstation 3 phat, slim and super slim resource search
                        by AJ847.63e
                        Hi All,
                        I recently got a bunch of faulty/partially faulty PS3s and wanted to get some advise on them. Models are:
                        X4 are PS3 slims with disc drive errors.
                        X1 is a PS3 slim with the 8002F1F9 update error.
                        X1 is a ps3 slim with no display.
                        X1 is a slim with RLOD
                        X1 is a super slim with a missing disc drive and receiving the same update error 8002F1F9 (I'm assuming because it needs it's drive)?
                        X1 is another super slim with no power (board number MPX-001).
                        Does anyone know of any good resources that list parts interchangeability?...
                        11-24-2025, 05:39 PM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • ongobongo
                        Asus ROG Ally - Super IO Chip replacement
                        by ongobongo
                        anyone here who has experience with replacing the super IO chip of an ROG ally?
                        I have one on my bench which has a burnt super io (ITE 5125VG-192). On some devices the super-io downloads it's firmware from BIOS if it's empty. As i don't have a programmer for this chips i hope someone here has already changed the chip and can give me a hint if it's working with an empty chip if it needs external programming.
                        Ongo
                        11-17-2024, 11:27 AM
