Memorex MLT3221 no power
    Re: Memorex MLT3221 no power
    Since we are looking for short, set the meter to Ohm mode 200 Ohm range, the use the probes on each legs of the Diode, take the reading, then reverse the probes and take the reading.
    Tell us what you get.
    • CR Designs
      • Dec 2012
      • 430
      Check with power on or off
        You will alwasy do this when you do any Diodes, transistors, capacitors, transformers, looking for shorts, you need to unplugged the unit from the outlet, and let the caps discharge for at least 5 minutes, especially that big cap.
        You will have it plugged in when you need to test the voltages.
        • CR Designs
          • Dec 2012
          • 430
          Both legs read 00.6
            00.6 Ohms? 00.6 K Ohms? If it is 00.6 Ohms then you need to pull it out as shown in your picture and measure it again off the board.
            • CR Designs
              • Dec 2012
              • 430
              I set the meter to 200 ohms. up above the dial there is 2000k and 200k. so i think i was at just 200 ohms. how what do I still pull the part and check it again?
                OK, if you're on 200 Ohm scale and the reading shows 00.6 Ohms on both directions, then verify it out off the board to be sure. You may have the same failure as shown in other thread.
                • CR Designs
                  • Dec 2012
                  • 430
                  O.k i will put the part. Your help has been great !! I will let you know what it reads when I get it out
                    I hope it is that simple, then it will be easy repair job for you.
                      If there is a history of the component failing you could get lucky.
                      These are really poorly made power supplies. Looks like Memorex/Imation chose the lowest bidden when choosing OEM for their TV.
                      • CR Designs
                        • Dec 2012
                        • 430
                        I pulled the part got the same reading on both legs 00.6
                          What is part # of device?
                          It is dead short so you have found the fault.
                          • CR Designs
                            • Dec 2012
                            • 430
                            Part number is Her30
                              Is it not HER304 as in the other thread? This should be a suitable replacement if it is HER304.
                              http://www.digikey.com/product-detai...SCT-ND/3191623
                              • CR Designs
                                • Dec 2012
                                • 430
                                The part is Her303,can I use the hero4 part? Also where can I find this part
                                • CR Designs
                                  • Dec 2012
                                  • 430
                                  I see I put the wrong replacement part number I guess it should Her304
                                    Yes you can use that part for HER303 or HER304. Basically the breakdown voltage needs to be the same or higher, and the current should be the same or higher, and it must be a fast recovery type.
                                    • CR Designs
                                      • Dec 2012
                                      • 430
                                      Where can I find this part?
                                        I just linked it to you.
                                        You can buy direct from Digikey. $3 or so shipping charge.
                                        • CR Designs
                                          • Dec 2012
                                          • 430
                                          I went to the website entered the part number, they have some listed but I don't know which one to buy, can you take a look and tell me what part number to buy,Thanks
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            09-06-2024, 05:59 AM
