SVA VR30 power supply issue
  • ed123
    • Oct 2012
    • 24
    I have a SVA vr30 TV that uses the outboard power supply salom electric ssu-s0061-1b.When the green LED no longer lights the TV will not work,this is a very common power supply issue.The telltale bulging caps are not present but it seems to be top secret on what common part is going in these supplies.I used to send them out for 80$ and they'd come back working.Now there is no-one and a customer would like not to throw away the set just because the supply is bad,does anyone know what the secret part that goes bad is or a source that wont break the bank for a supply?
    Ed
    Re: SVA VR30 power supply issue
    Any good clear pictures of this power supply, top side and bottom pictures. Bad cap can look normal but can have high ESR.
    • ed123
      • Oct 2012
      • 24
      Ok I'll try to take pictures tomorrow,I've tried replacing all the caps on a couple of these before and ended up buying the supply.
      Ed
      • ed123
        • Oct 2012
        • 24
        Hello again,
        I am back with the fix!
        100uf 16volt cap at location 1c24 infront of the 2 regulators fixed the problem.
        Ed
          Thanks for feedback, will help others in future.
          • Soulzink
            Samsug washing machine. Power supply DC41-00189a board issue
            by Soulzink
            I am trying to fix a samsung washinmachine power supply main board.
            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
            The power supply board reference is the following: DC41-00189a
            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
            04-19-2025, 06:26 AM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            07-01-2024, 06:34 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
