Samsung 32" ln32b360c5d
  • Peale
    • Apr 2009
    • 96
    Picked this up from Freecycle. Owner stated that it wouldn't turn on.
    She was /kinda/ right. It comes up, the Samsung chime plays, you get a perfect picture for a second...then it shuts off. It repeats this three times.
    I haven't had the opportunity to hook up a video source to it (the picture to which I referred was the on-screen menu) but I'm betting that it's continuing to operate. I found instances of people on the 'net who have had the same issue, but no mention of the fix.
    None of the caps on the power supply are bulging (though I'm sure I'll replace them, anyway).
    Photos, forthcoming.
  • Peale
    • Apr 2009
    • 96
    Re: Samsung 32" ln32b360c5d
    Here are the photos. I had to take two photos of each side of the power supply, since it's so large.
    I hadn't taken off the logic board before now, and I'm noting what appears to be something that spilled on it. I could be wrong.
    • TimT
      • Nov 2012
      • 268
      • us
      [QUOTE=Peale;297126]
      I haven't had the opportunity to hook up a video source to it (the picture to which I referred was the on-screen menu) but I'm betting that it's continuing to operate. QUOTE]
      are you saying that when the screen is blank your thinking the menu screen is still working? but cant be seen because the backlight is out?
      • Peale
        • Apr 2009
        • 96
        Exactly.
        And, when you power it off, it makes the Samsung power off chime, also.
          If I remember this chassis, some one in this forum found shorted diode in the power supply/inverter board, you may want to check those black diode with the silver band, set the meter to Ohm mode 200 Ohm range.
          I will search the forum to see find that thread.
          What is the P/N of this power supply/Inverter board? BN-XXXXXX, tom66 may have the diagram for it.
          • Peale
            • Apr 2009
            • 96
            It's a HV32HD_9DY, rev 1.4
            • Peale
              • Apr 2009
              • 96
              Oh, BN number - BN44-00289A
                Look like we are working on the same board in this thread.
                https://www.badcaps.net/forum/showth...196#post297196
                  You may want to read and check those parts also:
                  https://www.badcaps.net/forum/showth...ht=ln32b360c5d
                  • Peale
                    • Apr 2009
                    • 96
                    All of the diodes on the power supply board appear to check out.
                      OK. we should check the High voltage winding resistance of the transformers next.
                      We need to find the pin out of the inverter transformers.
                      • Peale
                        • Apr 2009
                        • 96
                        How do I find that out?
                        • Peale
                          • Apr 2009
                          • 96
                          I think I missed a diode from before - ZDI802.
                          In circuit, the diode has a junction drop of .095, both ways. I had to get out my Fluke to double check, but it seems to be reading as shorted.
                          So...now to source a replacement.
                          edit: anyone have the schematic so I can get a part number?
                          • Peale
                            • Apr 2009
                            • 96
                            It's reading fine out of circuit. I think I was getting a false bad reading from RI812 and RI813.
                              Schematic of PSU:
                              http://www.tgohome.com/ServiceManual...&Search=Submit
                                So far I cannot find the pin out of this transformer yet:
                                QGAH02107 TMB9
                                  It's on the schematic, but QGAH02110 instead, should be essentially the same part if the board is the same.
                                  Also have 289B, if that helps.
                                  • Peale
                                    • Apr 2009
                                    • 96
                                    Maybe I'm doing it wrong, but don't seem to be getting a reading out of any of the windings.
                                    Which can't be, since it comes up, briefly, when you turn it on, right?
                                      How are you checking the windings?
                                      • Peale
                                        • Apr 2009
                                        • 96
                                        Multimeter. Set to "2000" Ohms. Tried quite a few different pin combinations, didn't get any readings. So, I'm doing it wrong.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-X01DE boardview and NP950QCG-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
