va26lhdtv10t vizio
  • bobbyd40
    • Dec 2012
    • 116
    • usa
    Re: va26lhdtv10t vizio
    I took panel out because i noticed with panel laying face down and looking at front of it something in screen that looked like glass shards took apart to get at them to see what it was ,it was glass shards from edges of panel.
    probably why it went to white screen
    • jharvey58
      • Apr 2013
      • 3
      • usa
      Re: va26lhdtv10t problem
      I am also trying to fix a vizio VA26LHDTV10T. I have located a broken component (smd capacitor ??) on the lcd board in picture. ((I have no camera available, so borrowed a pic from bobbyd40's post to show what I am talking about.)) It is CP31. I need to find out if it is indeed a capacitor and what the specs are for replacing it.
      I experience loud snapping sounds from speakers and black screen upon powerup. If I disconnect the lcd ribbon from main board, sound stops and powers up to white screen.
      any ideas???
        CP31 is a cap, it is also conNected in parallel with CP30. Why do you think it is bad? does it show <1 Ohm resistance reading?
        • jharvey58
          • Apr 2013
          • 3
          • usa
          sending new pics (taken by phone) showing broken capacitor. Pretty obvious that it is no good.
          any ideas why I am getting the feedback noise through the speakers?
            When the MLCC cap is cracked, it will short out. So use the Ohm meter to find out if it is showing short or not.
            Disconnect the LVDS (FLAT cable) cable between the screen and the main board, then the TV should function normally with sound, you just will not have picture on the screen, you just see glowing screen.
            • jharvey58
              • Apr 2013
              • 3
              • usa
              #26
              you are very correct. I have previously disconnected the cable and found what you describe. Last night I replaced the cracked cap and set is now working properly.
              So, after 3 bad caps on the power supply (1000uf, 35v) and one on the T-con board, I have a working tv. Thanks for all the info and help. Hope others can benefit from my bad t-con cap problem.
                Great job, thanks for repair feedback.
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                • JDC
                  (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                  by JDC
                  ONN 100012588
                  Issue: No Power, Then Rebooting After Main Board Change
                  Short answer: replace main board and power board
                  Technical answer: replace main board and Q306 & Q307 on power board.
                  Long answer:
                  TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                  07-15-2022, 07:39 AM
