sanyo no back ligth
    replied
    Re: sanyo no back ligth
    You may want to bend the legs up a bit, it looks like the right leg is almost touching the pad close to it, otherwise, you got it right.
  • ealequi
    replied
    Ok, like this?
    replied
    I recommend the resistor in case the person accidentally short the lead to the chassis, that way the resistor will limit the current, base on this person experience, you are right, he should use the resistor.
    replied
    I always use it for safety just in case. Sometimes they rely on the main board using a resistor...
    replied
    There is Base resistor in series with the Base, and also a resistor between Base and Ground on the inverter board. Unless this is really badly designed board.
    replied
    It wouldn't limit current, if it is going straight into the base of a transistor, for example.
    replied
    By the way, IF you do not have the resistor, you can still use that Diode, but you will have the put the banded side on pin 3 instead.
    replied
    At least he has it on the right pins as I request. Make sure to tell us the color code of the resistor before you solder the resistor in place.
    replied
    I am not laughing, I am just making sure it is the right component. We all make honest mistakes.
  • ealequi
    replied
    hey don't laughg. iam learning.
    replied
    That looks like a diode, not a resistor?
  • ealequi
    replied
    is this what you mean?
  • ealequi
    replied
    i will try
    replied
    OK, leave the TV unplugged.
    Put the connector on CN2 back in place.
    Do not have the connector plug in to the C6.
    Get 1K any wattage will do, connect the resistor between PIN1 (5vstby) and pin3 (BL_ON) of CN6.
    Plug the TV into the outlet, hit the power switch, the backlights should come on.
  • ealequi
    replied
    on cn2 i am getting gnd,0,5v,0,0,12.5v,12.5v,12.5v,12.5v,0,0,15.v,15.v,3.2v
  • ealequi
    replied
    was a piece of dust.
  • ealequi
    replied
    ok. i do that now
  • selldoor
    replied
    Pic is very good one of the best I have seen for some time.
    If you pan along the white line in the middle to the hole
    Just below the hole there are 3 resistors and next to them
    C902 Just below that there is an odd bit of solder?
    May not be doing any harm but can you check it out.
  • ealequi
    replied
    check the fuse on the t-con, it is goog. iam going to put everything back together and do the test.
  • ealequi
    replied
    is this good?
