VIZIO L37HDTV10A: Lightning damage
  • martyparish
    • Dec 2012
    • 313
    Re: VIZIO L37HDTV10A: Lightning damage
    I tested it for shorts and noticed that pin 8(GND) and 3(CS) are shorted. Would that be normal?
    Any feedback is appreciated!!!
      Yes, that is normal. CS is connected through a low-ohm resistor to GND.
      • martyparish
        • Dec 2012
        • 313
        Thanks Tom.
        Is testing this IC with just a DMM is out of the question?
        Also, considering there is heat related discoloration visible, should I just consider that part cooked? (it's gonna take 3 weeks to get one!!!)
          That's the standby controller. If there was no power at all, suspect that. Otherwise, suspect something else.
          • martyparish
            • Dec 2012
            • 313
            Thanks for that info Tom, I'll not order it then.
            Here's an observation that may mean something. When putting voltage on PSON, the 5V standby begins to fluctuate. Does that set off any particular red flags?
              It makes me suspect a startup capacitor.
              • martyparish
                • Dec 2012
                • 313
                Hot damn, on to something now. Thanks for the nudge Tom
                Did the hair dryer test on the caps and bamn! after about ten seconds, the voltage stabilized. (should have done the dryer test long ago)
                Time to get some caps and go from there! Still got a main board issue as well.
                  Cap on primary?
                  • martyparish
                    • Dec 2012
                    • 313
                    I had already replaced the large cap. I aimed the heat right at the caps under the rightmost heat sink in this pic
                    I also did notice that the other rails still did not come on when the voltage stabilized.
                    I want an ESR meter!!
                      ESR don't be what kills those caps; no, Jimmy, it's leakage, I tell you! A normal ohmmeter will catch 'em.
                      • martyparish
                        • Dec 2012
                        • 313
                        Ah okay! I am getting reading on a few of them when testing resistance. They are still in the circuit though. I will pull em and retest. I'm slowly learning with your help thanks!
                        • martyparish
                          • Dec 2012
                          • 313
                          Hey Tom(or anyone who knows), how exactly do I test with ohmmeter? Am I looking for a dead short or a specific reading?
                            Ideally, you'd apply rated voltage across them to test for leakage, but any less than 100k on an ohmmeter after the reading settles is suspect.
                            • martyparish
                              • Dec 2012
                              • 313
                              Hey guys it's been a while but I am STILL not giving up on this tv
                              The latest is, I replaced(almost) all caps on the power supply and still have the issue with fluctuating voltage on standby/PSON. STBY is normal 5v UNTIL I jump it to PSON then it starts bouncing from 2v to 5v.
                              So, I thought one of the FETs nearby were gone but they check out ok. I even pulled one and it's fine.
                              I heated the area a little left of the area with all the caps and this time it stabilized much faster.
                              The one cap that I did not replace(stupid) is the 47uf 50v that sits right next to a transformer in the middle of the board. I'm guessing that is the start up cap???
                              If that is the start up, then I really feel stupid because Tom66 told me he suspected a start up cap and I replaced all BUT that one doh!
                              One of these days, I will get this PSU going so that I can then work on the main board. I'm hoping that the main is the common LDO issue...
                              Thanks for all of the help so far!
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Yes that is the cap. They are commonly 47uF 50v as you said your is, and they can make the PSU output fluctuate.
                                Muh-soggy-knee
                                • martyparish
                                  • Dec 2012
                                  • 313
                                  Update: I replaced the start up cap and still have the fluctuation issue. There is something else in that area that is shorted. I super quick shot(2-3 secs) of hot air straightens it out.
                                  I will keep investigating on that, but in the meantime I can still work on the main board.
                                  Question: What's the procedure of removing the LVDS cable from the main board? It's an odd looking connector and I don't want to do any damage.
                                  Thanks!
                                    Check the voltage across the startup cap.
                                    Also ALL small primary side caps should be replaced.
                                    The controller ICs can become leaky too, which can cause this fault as well.
                                    • martyparish
                                      • Dec 2012
                                      • 313
                                      That was fast Tom! Do you mean all ceramic and film caps on the primary? I'm guessing yes, since that's all I see on primary side.
                                      I am suspicious of that IC too! It really looked like it took some heat at some point.
                                      Regarding the LVDS cable, Should that just slide right up and out? I don't see any retainers on it just worried that I may screw it up removing it.
                                      Thanks yet again!
                                        I mean electrolytic caps. For now the poly caps aren't suspect.
                                        If you post a pic of the LVDS cable I'll make some suggestions.
                                        • martyparish
                                          • Dec 2012
                                          • 313
                                          Here's a pic. It's slightly blurred but hopefully clear enough for you to see the connector type. Thanks!
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
