LG 50PK550 turn on then off
  • PowerAmpFreak
    • 982
    • Sweden
    LG 50PK550 HD plasma, which tries to power on, all screen goes gray one second then turns off.
    I've read about the problems associated with the SMPS board, with the switching regulator ICE3BR1565JF.
    BUT - when taking some resistance measurements on the Y-BUFFER boards I noticed one thing that I need your opinion about.
    When Y-SUS board is connected to Y-BUFFER's I get a reading of 10ohms (exactly) across the small diodes pointed out with yellow lines in the attached picture. Is this a normal reading?
    As soon as Y-SUS is removed, the diode drops measures correct.
    I can't find any powercircuit failure on the Y-SUS board.
  • blib
    • Feb 2012
    • 56
    Re: LG 50PK550 turn on then off
    Check and replace 2 X 22ohm 5 watt resistors on smps
    • PowerAmpFreak
      • 982
      • Sweden
      Thanks, but please clarify.
      Does those resistors if open, causing SMPS to shut off?
      Nothing to do with the ICE3BR1565JF controller then?
      What about the 10-ohms reading on buffer boards, normal reading?
      • blib
        • Feb 2012
        • 56
        Had this fault twice now.Turned out to be one of the two stand up resistors on the corner of the board.If the ICE3BR1565JF goes I think it takes out the fuse nearby.
        • retiredcaps
          • Apr 2010
          • 9271
          These threads might be relevant...
          https://www.badcaps.net/forum/showthread.php?t=24646
          https://www.badcaps.net/forum/showthread.php?t=25145
          --- begin sig file ---
          --- end sig file ---
          • PowerAmpFreak
            • 982
            • Sweden
            Blib, thanks a lot. It was one of the 22ohm resistors!
            Set is up and running again!
            *** HAPPY NEW YEAR TO ALL OF YOU ***
            • Acosta_Brazil
              • Jan 2017
              • Brazil
              Dear friends, I have uam TV LG 50PK550 with the following problem: When I turn on the TV, the screen blinks and turns off, but the TV does not turn off or goes into stand by.
              I can measure all the voltages of the power supply and are perfectly ok, according to LG technical guide.
              I was measuring the crystal oscillator of 54 MHZ with the oscilloscope and no signal. I changed the oscillator crystal and it did not work.
              I disconnected the LVDS cable from TCon and closed the jumper next to the R51 and R52 resistors. The screen lit up perfectly and was self-test.
              Anyone have any suggestions?
              Could it be the BCM3556?
              • pajdek
                Lenovo Y700-17ISK turn on and off
                by pajdek
                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                09-20-2023, 02:49 AM
              • RdeveLabs
                MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                by RdeveLabs
                To all the members here...
                Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                05-05-2025, 04:59 AM
              • robante15
                Acer Aspire 4520 won't turn on after reboot
                by robante15
                Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                If I remove the...
                04-06-2024, 06:50 PM
              • masoksian
                Dell latitude e7470 not turn on .power buton on off and Run Power problem
                by masoksian
                I am dealing with the problem of turning on and off my Dell e7470 notebook.
                The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                The system does not turn on, there is no post.
                I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                The problem continues in the same way.
                I tried to turn on the Fn key, nothing came to the screen....
                02-15-2025, 12:08 PM
              • Ledgurra
                MacBook Pro A1425 it doesn't turn on
                by Ledgurra
                hello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
                thank you all
                11-09-2025, 06:07 AM
