Panasonic STV 5v sense DG Board Repair
  • fahd_ahm
    • Dec 2012
    • India
    I have had this Panasonic Plasma on me for quite some time. Recently it just went off one fine day. I have been trying to get it fixed but to no avail. The authorized dealer says it will cost me about 300 USD to replace the power board. Alternatively have checked with a lot of local micro-electronic dealers but they are not that bothered about fixing it.
    i did a bit of online searching and the error i found is the 'STV 5v sense DG Board'.
    I don't know what it means or what is to be changed or fixed.
    Any Help will be appreciated. The model is THP42X10D. Panasonic Viera.
    Re: Panasonic STV 5v sense DG Board Repair
    When turned on, the light should go green, then flash red.
    Count how many times the red light blinks and tell us. The light should have a blink every 0.3 seconds, then pause 3 seconds before repeating the code.
    • fahd_ahm
      • Dec 2012
      • India
      it blinks 1 times. i checked various websites it says 1 blinking red light means the fault is STV 5v sense DG Board.
        It can also indicate "No particular check point", i.e. general error.
        • fahd_ahm
          • Dec 2012
          • India
          so what does one do to get it fixed. The panasonic guys said that the power supply is gone bad and the whole card needs to be replaced. i was wondering if there is a way to find out if there is any specific component that has gone bad and can be replaced.
            I doubt it's the power supply. The DG board would be a good guess, but does this TV also have an "A" board?
            • fahd_ahm
              • Dec 2012
              • India
              sorry for the late reply. The DG board is what the various websites say. how does one figure out which component has gone off.
              also could you clarify on what an "A" board is...maybe then i can shed some light on that.
                It may be present on only newer Panasonic sets but the "A" board has the video inputs AND HDMI on it.
                • adamp91gvm
                  • Jan 2014
                  • 699
                  • uk
                  Hi I have the same 1 blink did a fix come for this
                  • adamp91gvm
                    • Jan 2014
                    • 699
                    • uk
                    • AnthonyG
                      • Feb 2021
                      Did anyone have more insights into the STV 5v sense DG Board 1 blink issue possibly
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                        After all of...
                        07-13-2024, 08:14 PM
                      • canadaboy25
                        Panasonic TC-P54VT25 No image. A or D board?
                        by canadaboy25
                        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                        01-17-2021, 01:06 AM
                      • dajoker
                        Panasonic th-p50s10d - blinky red, SC board go boom
                        by dajoker
                        My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
                        I chased my way through the PSU, and a board, with no results.
                        Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
                        I only have the right half of the picture.
                        Left half is completely blank.
                        now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
                        all the other voltage rails...
                        09-24-2024, 04:39 AM
                      • Rictech
                        Panasonic SA-MAX770PU SMPSU board fault....
                        by Rictech
                        Hello everyone. 😀
                        As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                        Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                        Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                        This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                        There are no devices that have exploded or otherwise show signs...
                        08-26-2024, 01:05 AM
