Sanyo DP50747 problems, where to start?
  • gravityfeeder
    • Dec 2012
    I am new to this forum.
    I purchased a non functioning Sanyo DP50747 plasma tv. I checked the fuses and looked over the capacitors on the power supply board and they "look" good.
    If someone can offer guidance or tips.....
    Stefan
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Sanyo DP50747 problems, where to start?
    I would say buffer board(s), the power supply and panel obviously work, the sustains seem to be working. Can you take clear pics of the inside of the set?
    • jean luc ferre
      laptop hp g72 b52sf screen problems
      by jean luc ferre
      on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
      the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
      i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
      i don't understand the reasons of the white stripe at the bottom of the screen below the task...
      06-07-2025, 03:27 PM
    • Hondaman
      USB problems?
      by Hondaman
      Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
      (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
      I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
      08-12-2024, 03:26 PM
    • MagicSmoke
      Older Sanyo DP50747 VE Voltage High
      by MagicSmoke
      Working on an old Sanyo 50" that has Samsung innards. Backstory.. saved from dumpster years ago, partial recap on SMPS, Replaced one of two small caps on X-main, set worked great for about 3 years.
      Then recently it started to take a few minutes from power on to display a pic and sound, worked like that for about 3 months, then Smps would click once and then nothing, it will not shut itself off but nothing happens.
      So pulled PS replaced all the caps, even the large mains. PS works and has all stable rated voltages present when switched on. TV has sound (static) when...
      12-02-2020, 11:56 PM
    • clabr
      Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
      by clabr
      Need help to solve some problems with this laptop.
      After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
      After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
      Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
      Before this had happened I observed some other problems:
      When I tried replacing original mecanical HDD with a SSD HDD could not get them...
      12-02-2021, 08:09 AM
    • cj_reha
      Mystery 80s Sanyo cap - perhaps polymer?
      by cj_reha
      Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
      01-06-2023, 09:24 AM
