Hitachi 46F500 power surge
  • ryan74
    • Oct 2012
    • 471
    • usa
    Major power surge blew this tv and first thing I noticed was a bad main fuse 125V. 6A and what I think is a ZNR Transient/Surge Absorber ZNR V10241U.
    I dont know anything about surge absorbers.
    Nothing seems burnt on power board but the surge must have melted the solder on the absorber, it pulled right out of board with no heat. there are 2 other 125V. 5A. buss fuses that are fine.
    Im going to replace the absorber and fuse but I was wondering if the surge would have MOST LIKELY stoped at the absorber when it blew. I will order 2 just in case.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Hitachi 46F500 power surge
    I don't have an answer for you, just a question. Were the absorbers in the circuit before or after the blown fuse?
      If you're lucky that's where the damage stopped. Hopefully it didn't come in through any of the video inputs and fry something on the main board.
      • ryan74
        • Oct 2012
        • 471
        • usa
        After.
        Part seems to be obsolete and Im having trouble reading the last part on it, it is a little burnt.
        ZNR
        V10241U
        ?CD
        Im not sure of the manufacturer/replacment.
          You do not have to replace the MOV yet, if nothing else is damaged, the TV should power back up OK. I would suggest using 150W lamp in place of the fuse, if the lamp stays brightly lit when power caord is plugged into the outlet, that will indcate you still have shorted out circuits in the TV. The TV will work without the MOV, the MOV is put AFTER the fuse so when the first surge comes along, the fuse will blow so if there is a second surge the TV will not be exposed to the second surge.
          By the way, that is 150V (code 241, Max allowable =150VAC/200VDC ) MOV, it looks like either 10mm or 14mm diameter. You can get it from Mouser or Digikey.
          14mm:
          http://www.digikey.com/product-detai...41K-ND/2799114
          • ryan74
            • Oct 2012
            • 471
            • usa
            I called digikey and they said they didnt have anything to replace that part.
            Mouser gave me this.
            http://www.mouser.com/ProductDetail/...nLmFzxP794I%3d
            on my way to town to pick up a 150w bulb unless fuses are cheaper.
            • ryan74
              • Oct 2012
              • 471
              • usa
              The boards were filthy so I cleaned them and replaced fuse and have MOV removed.
              Set powered on and I could see the lamps start to glow red green blue untill they shut off after 5sec. set remained powered(red front led).
              The power board has 5 led on it and 1 is red. see pics
              --Edit-- seems to be working. I have cable hooked up and it has pic and sound.
              Is there a reset or factory mode?
              all i have is the attached pdf
                I think this is a CRT rear-projection TV. Must be heavy! Nice 1080i set but how's the convergence?
                • ryan74
                  • Oct 2012
                  • 471
                  • usa
                  yes it is crt rear projection. weighs over 100lbs.
                  Im such a amateur Im not sure what convergence is.. I havent read up on it yet.
                    Convergence is basically how well aligned the red, green and blue tubes are. It's pretty normal for them to drift after some time. Usually adjustment is possible from user menu or service menu.
                    • ryan74
                      • Oct 2012
                      • 471
                      • usa
                      I just read a bit about it.
                      thought I would take a couple pics from about 4ft away.
                      -Edit- which part would be best? the digikey or mouser.
                      If it doesnt matter ill go with digikey. they are faster and cheaper shipping.
                      the original part diameter is 10mm
                      I found this also same as mousers part
                      http://www.digikey.com/product-detai...41K-ND/2407562
                      • ryan74
                        • Oct 2012
                        • 471
                        • usa
                        I was looking inside to see how dirty the mirror was and saw something odd on red lamp.
                        it looks like a thin strip of electrical tape.
                        Is windex ok inside on lamps and mirror?
                        • ryan74
                          • Oct 2012
                          • 471
                          • usa
                          I ran this tv about 72hrs. testing before selling on sunday.
                          Three days later I get a call it has wavy lines on right side of screen.
                          I go to look at it and he said it just shut off and wont turn on.
                          It attempts to power on but shutsdown right away.
                          I took tv back
                          back to troubleshooting
                          -Edit-
                          I removed the board and when I plug it in it makes noise around what I think is a relay(pic 2).
                          After 5-10 sec noise stops and led's light up on board.
                          Its not a chirp or squeel but more of a vibrating buzzing sound
                          • ryan74
                            • Oct 2012
                            • 471
                            • usa
                            (above)I suspect a bad cap but who knows.
                            I think this has something to do with calibration from what I have read on other sites.
                            • ryan74
                              • Oct 2012
                              • 471
                              • usa
                              I removed the power board and when I plug it in, it makes noise from the relay in pic above. this is probly from a bad relay or voltage issue. I have bad luck locating fet's and leaking caps that havent completely failed so I would like to verify correct voltage at relay.
                              Any tip for troubleshooting or schematic?
                              Im not possitive it is a power supply issue but pretty sure and I dont have service manual/schematics.
                              The power board is stamped
                              DP2X
                              #JK08024-A
                              the next numbers are smeared in black ink
                              DP23A/32AB
                              IDICT29C04
                                Any time you suspect the power supply, first rule is, "thou shalt check voltages." Basically all a PSU does is give you voltage rails. Are they there or not? If they're there, look elsewhere, otherwise, consider the PSU.
                                • ryan74
                                  • Oct 2012
                                  • 471
                                  • usa
                                  I noticed voltages printed on bottom of board so I checked each pin.
                                  Most were 13v while the relay made noise then went up to 20v and the led's turned on board.
                                  The 10v was only 3v.
                                  I also noticed when power is applied to board I only get 55v at main fuse.
                                  Seems to be low voltage overall.
                                  The varistor I replaced looks ok but I may pull it and see what happens if I power up the board.
                                  Any tips as to what I should check now?
                                  Edit- I swear I was reading 20v off ground pins also. I may have to recheck that.
                                    The transformer outputs are ac, you cannot measure them with dmm.
                                    You need to measure the output voltages on the connector.
                                    Leaky caps don't cause this problem, high ESR maybe, board uses very good ones though, so it is unlikely.
                                    • ryan74
                                      • Oct 2012
                                      • 471
                                      • usa
                                      The readings I took were ac. Can you explain why that cannot be measured with a digital multimeter?
                                      The cap question was partialy unrelated to this post. I just threw the question in.
                                      I will have to take pics and post results of connector voltage. Theres a few connections and I dont know which to test.
                                      • plc
                                        Pardon me friends. I have this same board from a Hitachi television. I'm wondering if I can get a point in the right direction.
                                        Here are my set's symptoms:
                                        Unit worked flawlessly for about a month
                                        Unit was working with a slight buzz just before it stopped working
                                        Unit now turns on, audio pops, but no tubes light up
                                        Any media player turning on will turn on the set
                                        Remote will turn unit on
                                        Remote will not turn unit off
                                        All LEDs on board light except D928, which checks on a DMM
                                        I am inclined to believe that whatever power source which powers the imaging and audio section of the digital board is not sending power.
                                        I am inclined to believe that a relay has failed
                                        S901 and S902 conduct across the coil side
                                        S903 and S905 do not conduct across the coil side
                                        I am at the limit of my TS understanding
                                        Thanks for any help
                                        Philp
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • wolf1976
                                          hitachi 50hk5600 problem with display
                                          by wolf1976
                                          hi
                                          i have the above tv and the display starts distorts the display at only in applications like you tube
                                          after and on the didital channels
                                          now without connect the antenna only the image of itsselfs tv i have the image i have in attach
                                          i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
                                          can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
                                          09-13-2025, 02:26 PM
                                        • massimomax
                                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                          by massimomax
                                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                                          Post in English !!!
                                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                          02-28-2025, 07:27 AM
                                        • dragometin
                                          Hitachi 40HYC42
                                          by dragometin
                                          TV Model: Hitachi 40HYC42
                                          Power Supply: 17IPS71
                                          MainBoard: 17MB95M
                                          Panel: VES400UNDS-2D-NO3
                                          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                          Is there any variants on 17IPS71 power supply's?
                                          UART output pins 10 and 12 on scart connector:
                                          Code:
                                          12:24:04.595
                                          08-08-2024, 05:53 AM
                                        • sotodefonk
                                          Help finding the correct model of a T-Con board on my Hitachi TV
                                          by sotodefonk
                                          Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
                                          I opened the tv to access the board and took the shared pictures of the T-Con board.
                                          I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
                                          I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
                                          Inspecting...
                                          06-28-2024, 04:39 PM
