Wrong board... you need to swap the X-main, not the Y-main when you get those symptoms.
Check the Yfr and Yrr settings on the new Y-main. Tweak them gradually and see if the picture improves. Also, check the Vset, Vsc and Ve voltages. In particular a low Ve can sometimes cause this.
Have you adjusted Yrr too?
Post a close shot of your power supply (both the main one and the smaller sub-one), I can help you locate the test points.
OK, the first step is to adjust the VS, VA voltages so that they are within 1V of the specification. (Ideally +/-0.2V.) The specification is on the back of the plasma panel, the sticker that says NTSC/PAL.
To adjust you need to measure the voltage at the particular test point and
Once you have adjusted those post a picture of the white board adjacent to the power supply -- it has the other voltages on it which are also important for the plasma display to work properly.
Good. Now check Vscan and Vset. There could also be a Ve voltage, though that might only be present on newer displays.
BTW, did you ever fix the Panasonic P50G20E?
Panasonic me crazy too ,Work 2-3 days and then goes bad, If you leave after 5 minutes a bad job works that never damaging. sometimes do not want to Tuned ON. I do not know what to do
Hmm, I cannot think what is causing the issue if all the voltages are good. tieny found that he had a shorted transistor in the Yfr/Yrr area which was causing overdiffusion. You are seeing underdiffusion in this case, but either would be possible. You replaced 5 FETs but maybe that wasn't enough...
I suggested you reflow the Panasonic board, did that have any effect?
See the symptom looks exactly like a failed X board but you said you'd replaced it. Are you 100% sure it is a working board?
