SAMSUNG PS42D51SX bad picture
    Re: SAMSUNG PS42D51SX bad picture
    For SMD resistors above or equal to 0603 size (1.6mm x 0.8mm) the value is printed on them using a code.
    e.g. 101 indicates 10 x 10^1 or 100 ohms.
    e.g. 470 indicates 47 x 10^0 or 47 ohms.
    Values smaller than 10 ohms are indicated using a number-number-letter code.
    http://www.marsport.org.uk/smd/res.htm
    • kevinm34232
      • May 2012
      • 1884
      OK so it was a 100 ohms resistor that was bad on control board, that was reading 1.7k ohms?... If not just for me for anyone else that winds up here..
        47 ohm that read 1.7k.
        • Judy
          This looks like the same picture on my Samsung plasma 50". How do you know what part to order?
            You've posted three times already and both of those times I've said it was the X-main.
            I'll make it a third: It's the X-main board.
            If you need help locating the exact board then reply and I or someone else will be happy to help.
            • Judy
              Where do I order it, I am new to this site. Thank u!
                Can you post pictures of the X-main board.
                This is the board mounted on the right of the plasma panel (looking from the rear) connected to the orange ribbons.
                On it there will be a part number, usually LJ41-xxxxxx[A-Z] indicating which part to order.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  #108
                  Nevermind, posted too late. tom66 explained it already.
                  A working TV? How boring!
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      #110
                      I posted in reference to the last post on page 5, but by the time i hit reply, other posts were made.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        It took you nearly four months to hit reply?
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          #112
                          Well... that was something i didn't spot. I got sent here following a link in another topic, and i guess i was on page 5 and had a brain fart. It happens.
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • ohren
                            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                            by ohren
                            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                            The models launched in 2018 and 2019 respectively....
                            09-08-2023, 05:24 PM
                          • C152Heavy
                            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                            by C152Heavy
                            Summary for TL-DR readers:
                            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                            • Have obtained Samsung schematic & service documents - Can upload if helpful.
                            • Have read ALL applicable threads
                            • C1818 and CP820 replaced as low hanging fruit
                            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                            • VCC pin (18) of PFC...
                            01-11-2023, 02:53 PM
                          • ermals
                            Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                            by ermals
                            Hi all!
                            I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                            1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                            2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                            3. I've checked voltages...
                            08-01-2022, 10:35 AM
