Toshiba 37HL67
  • pacmania
    • Dec 2012
    Toshiba 37HL67
    Seems like my Toshiba 37HL67 has experienced common Toshiba problem of blinking LED and no power on.
    Where is the best (cheapest) place to get the repair manual for this or similar TV?
    I have ordered a small (32mb) SD memory card in attempt to reload software as was suggested on internet. It's amazing how fast this stuff goes obsolete, I had no problem finding a 32GB card.
    All power looks good (going off labeling on board I have no schematic) so for instance 24INV measures 23.96.
    There is a yellow and green LED on Seine board. These are side by side at lower right. When TV does not turn on the yellow is on. when TV does turn on green is lit.
    I am fixated on a very small SMD electrolytic cap on seine board. I am not sure that's my problem but I am going to look there first.
    Any help on repair manual or schematic would be appreciated.
  • randtek
    • Oct 2011
    • 280
    • US
    Re: Toshiba 37HL67
    First worry about the software reload. That will probably fix your problem on this model. You don't want to be messing around with circuitry if it's not necessary.
    • pacmania
      • Dec 2012
      Re: Toshiba 37HL67
      That sounds easy, and have not tried it yet, but there appears to be a catch-22 here in that the TV must be on to load software. I'm not sure what happens if TV does not come on at the time I am trying to load software.
      Sometimes TV comes right on. Sometimes I have to unplug several times for TV to start.
      • randtek
        • Oct 2011
        • 280
        • US
        Re: Toshiba 37HL67
        Actually, this model does not need to be turned on for the software update. You insert the prepared memory card, then plug the set in. It will update even if it wasn't able to be turned on. FYI, this is a repair for the 3 blink error code. When you try to turn the set on, it just blinks 3 times, repeating.
        • pacmania
          • Dec 2012
          Re: Toshiba 37HL67
          Question about firmware update, The recommended file is compressed 2007SEN069. When you open there is what looks like 3 different files.
          USTV07S3.prg
          USTV07C3.prg
          USTV07S2.prg
          Also there is a folder associated with each .prg with 2 files in
          bootimg
          flashimg
          Does anyone know which one is used (S3,C3,S2)? Also the instructions on Toshiba web page say no folders but when you extract file the bootimg and flashimg are in a folder.
          • randtek
            • Oct 2011
            • 280
            • US
            Re: Toshiba 37HL67
            Put all 3 of those files, and all 3 associated folders in the root directory of your SD card. I do not know or care which files are used, I assume it may take all of them. I just know it works.
            • randtek
              • Oct 2011
              • 280
              • US
              Re: Toshiba 37HL67
              Here is a link to a site that has pretty good instructions for the update
              http://www.benjammin.net/www/pages/t...a-42HL167.html
              • pacmania
                • Dec 2012
                Re: Toshiba 37HL67
                Put all files on card formatted to FAT 32 (windows XP) and installed. TV started following installation. There were no menu prompts while installed - blank screen. This isn't what is implied in Toshiba installation instruction. But:
                Original installed:
                HL07
                3.2.35.0
                Feb 22 2007 11.59.31
                FW:13
                New installed
                HL07
                3.2.69.0
                OCT 17 2007 14.25.37
                FW:13
                TV turned on 10 times in a row. Will check it for a few days and will update. I hope this helps anyone with this blinking LED - no power problem. Thanks for the help.
                  Re: Toshiba 37HL67
                  Glad to hear you fixed it and posted back the fix.
                  Nice that you can fix dead firmware from SD. Most require re-flashing jig...
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Re: Toshiba 37HL67
                    I have just picked up a 42"(42HL167) version and it acts differently.
                    It works for a while and then the whole screen is like flooded with a black fluid.
                    That is how it looks like. Sound is working OK.
                    Do you guys think that this is a software issue, or something else?
                    Maybe capacitors?
                    I haven't had time to open it up yet. It was to late last night went I came home with it.
                    • randtek
                      • Oct 2011
                      • 280
                      • US
                      Re: Toshiba 37HL67
                      I doubt if it is software tibimakai. I would like to see pictures of that symptom.
                        Re: Toshiba 37HL67
                        I would suspect t-con, or t-con power or panel.
                        If picture freezes, t-con/t-con power.
                        If picture continues, panel.
                        • mcross
                          • Sep 2011
                          • 201
                          Re: Toshiba 37HL67
                          I have a 37hl67 it shows a picture but has like a lite negitive image around the picture, on the menu it has a pink color on some of the image. have tried remove and reset ribbon cables to t-con .
                          Any thoughts?
                          Mike
                          • $p@rk/3$
                            • Dec 2014
                            • usa
                            Re: Toshiba 37HL67
                            Hi I have a Toshiba 37HL67S. I get no digital input signal or sound. I can pick up ant. No sound I replaced the main a/v board but still the same. But with av cables. It don't say no Sig just a black screen and still no sound please help. My father in law is jumping down my neck to fix it
                            • regzahhhh
                              • Jan 2020
                              Re: Toshiba 37HL67
                              I know this thread is really old. Hopefully someone will stumble upon it and be able to help. (Warning: I am in no way a techie!)....
                              After suffering with this Toshiba yellow blinking lights syndrome for several years I became emboldened enough to try the software update. It did nothing. Don't know if I did something wrong (wrong sized SD card, wrong format, did or did not extract to the correct "directory," etc.)
                              - I used a SanDisk Ultra SDXC UHS-I 64GB card.
                              - I did not know if I should format the card or not. The two options for formatting (Win 10 PC) are 1) exFAT (Default) and 2) NTFS. A large number of "allocation unit size" options are available from which to choose.
                              - I attempted this firmware update several times. I reformatted the SD card several times in various formats. I downloaded file 2007SEN069.zip to my hard drive then unzipped the files (3 folders and 3 files - as mentioned in another post) to the SD card.
                              - I inserted the SD card with the TV power off. I inserted the SD card with the TV power on. (Two rather glaring differences (?) between Toshiba's directions and those found elsewhere online.)
                              Each time I tried something different the TV acted as if there was no SD card installed. Help/suggestions appreciated. TIA
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                Re: Toshiba 37HL67
                                Most/all TVs want a FAT32 file system, try that first.
                                • R_J
                                  • Jun 2012
                                  • 9546
                                  Re: Toshiba 37HL67
                                  with windows 10 and a usb of less than 32Gb I believe the fat32 format is available, If the drive is larger, it is not.
                                  The work around is to use the command prompt BE CAREFULL You need to know the drive letter of the usb stick, then at the command prompt type: format /FS:FAT32 H: where H is the usb drive letter
                                    09-06-2024, 05:27 AM
                                    09-06-2024, 05:59 AM
                                    Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                    This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                    09-06-2024, 05:33 AM
