Samsung LN40A330J1DXZA 40" LCD no power
  • 8cuda
    • 46
    Black screen, no power and sound. Slight flash on the right side of the screen when the power button is pressed.
    Should all the capacitor be replaced or just the bulged caps(see 2nd photo)?
    I'm new to fixing TV. I have fixed iMac G5 bulged capacitor on the logic boards and power supplies.
    Randy
  • Zalinar
    Zalinar
    • Sep 2012
    • 10
    Re: Samsung LN40A330J1DXZA 40" LCD no power
    Hi. Great photos!
    If you replace the bulged ones, that should fix your problem. However, it is a good idea to just replace them all while you have it open and apart. Even if they are not bulged, they may still be dried out from age and heat. They just don't show the obvious signs of failure.
    Hope this helps! This is my first reply here! Yay!!!!
    • 8cuda
      • 46
      To clarify, will these Rubycon caps from the site would be a good choice?
      1000uF 25v ZLJ 10mm 20mm
      820uF 25v ZLK 10mm 20mm
      470uF 25v ZLJ 10mm 12mm
      47uF 50v RX 8mm 12mm
      • Phaihn
        • Jan 2009
        • 842
        they would suffice as long as they fit whare they need to go.
        My Computer.
        AMD APU A4-3300 2.5ghz 1mb cache
        Motherboard GigaByte GA-A75M-S2V
        Kingston HyperX Blue DDR3 8GB (2x4GB)
        SB Audigy 2 ZS [B800] Sound Card
        500GB WD Caviar® Blue™
        1 Terabyte WD Caviar® Black™
        2 Terabyte WD Caviar® Black™
        • 8cuda
          • 46
          Fixed: Samsung LN40A330J1DXZA 40" LCD no power
          I replaced the two bulged caps, as I had a few extra 1000 uF 16v from my imac G5 power supply days.
          The Samsung is working, saved the TV from the landfill/recycler
          Thank you Zalinar & Phaihn, will monitor the TV and may change the rest of the caps upon failure.
            Good job, but I would have replaced them as a set, since bad caps will not filter out the AC and let the AC feeding the circuits, that can cause damages (such as over heating of the components) to the circuits before the caps completely failed.
            • Phaihn
              • Jan 2009
              • 842
              My Computer.
                Why are you posting a picture of a plasma?
                That is more than likely loose connections on the Y-buffers, but put it in the right thread please.
                • Phaihn
                  • Jan 2009
                  • 842
                  arge looks like i missread the titla i was looking for my thread...
                  My Computer.
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • mrtek
                    Samsung UN43NU6950FXZA No power
                    by mrtek
                    Hi
                    Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                    Main fuse = OK
                    Back light LED = OK. Power them with aux power source
                    LED output = OK 156V
                    I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                    Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                    07-20-2025, 08:06 PM
                  • hill01
                    Samsung UE75MU7009TXZG Endless Power Cycle
                    by hill01
                    Hi everyone and thanks in advance for any help I might get here
                    My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                    About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                    Since a few days, the TV won't turn...
                    11-17-2021, 02:52 PM
